Home Forums Software Discussions Corel Software Help please, managed to lose a pallette
  • Help please, managed to lose a pallette
    Posted by John Parfit on 9 March 2011 at 15:58
    Hope someone can help, very frustrating.
    While adjusting a rectangle I somehow managed to ‘fling’ one my docked palettes (I had rgb and pantone sitting on the right side) completely out of the viewing window or somewhere above the top of the window and I cannot get it back.
    Does anyone know of a way to retrieve it, I’ve tried deleting it and restoring it in ‘windows – palettes -‘ but it seems it restores somewhere out of view
    Don’t really want to try a F8 default since I’ve got Corel set up with a fair bit of customisation.
    John Parfit replied 14 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Tim Painter
    9 March 2011 at 16:33
    I don’t think you can loose the palette off the edge as you can have it in a separate window or I presume another monitor.
    I still think it is a setting.
    What version of Draw?
  • Tim Painter
    9 March 2011 at 16:36
    Just found this……….worth a shot.
    Re: [coreldraw] Re: CorelDraw x3 – lost color palette
    | It must be opened somewhere but for the life of me I can not find it.
    I recall someone with similar problem a couple of years ago. Said he must
    have accidentally shoved a docker (or some such) off the screen with his
    mouse, and no amount of F8s, etc., would bring it back. He finally tried
    increasing his computer screen resolution to make everything smaller and
    found it off to the side–and retrieved it.
  • John Parfit
    9 March 2011 at 17:04
    Thanks very much for that Tim, weird but seems to make sense somehow; will try the resolution trick in a little while…. could not believe that I’d lost it ‘out of corel ‘ myself but at first there was a part of the palette hanging down but when I tried to retrieve it I sort of nudged it out of view and no amount of trying could get it back 🙄
    Thanks again, X4 by the way, although we also have X5.
  • Martin Grimmer
    9 March 2011 at 17:31
    Hi John,
    Have had a problem in the past when the programme I was using wouldn’t work because the dialogue box (that needed to be pressed first) was off screen and couldnt be found.
    Never thought to do what Tim suggested, but used a different method which may help??
    (following from internet)
    Press Windows Key + M (minimize all windows.)
    Use Alt+Tab until you have the missing window active, and release the keys.
    Right-Click on the taskbar and choose Move from the Context menu. Now you should see that your mouse pointer changes into a crossarrow. There is of course nothing to drag or move on your screen, so:
    Depending on which side of the monitor you have extended your desktop, use the arrow-keys (up,down,left,right) to maneuver the window back in place.
    Maybe might help?
    Martin
    [/i]
  • John Parfit
    9 March 2011 at 18:42
    Well, well; tried both of your suggestions but no luck I’m afraid but as a last gasp effort before re-installing Corel I tried using a restore point for Windows (not Corel) to an earlier time before I mistakenly sent my palette into the ether; and it worked! no idea why but it just came back again like it had never been away.
    Phew 😮
  • Tim Painter
    9 March 2011 at 19:17
    Now Back Up your customised Corel settings John and keep it handy encase you do need to use F8 in the future.
  • George Elsmore
    10 March 2011 at 08:05
    how do you back up your customised corel settings Tim
    10 March 2011 at 08:26
    George, place cursor over toolbar and right click – customise – workspace – export.
    John, not heard of a pallette going missing to that extent, do other pallettes open ok?
    Alan D
  • John Parfit
    10 March 2011 at 08:52
    Yes, lesson learned here Tim, shall copy my customised workspace.
    Really was a wierd one Alan, all palettes showed OK, even the one I lossed. I wondered if I had somehow managed to pick up the palette docker and place it somewhere else inside Corel and not outside, for example somewhere in the title bar/toolbar/menu bar ; I had a look around but couldn’t find it though.
