Home Forums Sign Making Discussions CNC Router and Engraving help please im having problems with engraving?
  • help please im having problems with engraving?
    Posted by Adrian Neill on 12 July 2007 at 09:05
    Good morning ……..
    We run a Dahlgren SYS-2516 engraver. We are currently having problems
    engraving brass plates. Whatever settings we change the edges always
    burr. We always used to sharpen our blades to 45 degrees and be able
    to engrave pretty much any depth and run the machine as fast as we wanted.
    We’ve recently had to sharpen our blades to 60 degrees and it works
    ‘most of the time’. Not sure if anyone has any tips ??
    We have no problem engraving stainless steel on the same machine.
    Cheers.
    Graeme Harrold replied 18 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Graeme Harrold
    12 July 2007 at 10:10
    First question is where did you get the brass???? When I started I used brass sheets supplied as just brass sheet and had the same problem. Engraving brass is categorised as "half hard" and should cut very smoothly without any lubricant and since switching to engraving brass Ive not had any problems. If you are sharpening your own cutters you may need to adjust the other angles too, clearance, rake etc…….will look these up later and post tonight.
    I use a Dahlgren Wizzard 2000ST on a medium XY speed and 3/4 spindle speed. Only cut down .03 to .05" at a time. I use standard Suregrave cutters.
    Hope this helps
  • David Lowery
    12 July 2007 at 10:23
    Definatlely sounds like the brass to me if the machine is OK ON stainless.
  • Adrian Neill
    12 July 2007 at 12:12
    nice one !! i did wonder about the brass itself ……
    going to try the ‘half hard’ brass and see what happens. 😀
  • ZOE FENWICK
    8 August 2007 at 10:54
    Hi Ady
    I’m new to this, just wanted to no haw you got on with the ‘Half Hard’ Brass. I have been working in this industry for 12 years and was always been lead to believe that you actually need ‘Hard’ brass for engraving.
    Look forward to hearing from you
    Zoe
  • Steve Thornton
    22 August 2007 at 15:39
    Anyone got a good supplier for Brass for engraving (sorry to steal your thread)
  • PhilGreen
    22 August 2007 at 16:08
    Try Pantograph Services, Leeds or Engravamet (I think they are in Nottingham). both supply CZ120 polished brass in various thickness.
    In 1000mm x 600mm sheets or cut to size.
  • Graeme Harrold
    22 August 2007 at 17:00
    Could also try http://www.Mastergrave.co.uk, http://www.Suregrave.co.uk and http://www.Gravograph.co.uk, they all do full sheets (4′ x 2′) or cut to size in various thicknesses.
