Home Forums Vinyl Cutter Discussions Roland Cutters Help! Paths are cutting twice…
  • Help! Paths are cutting twice…
    Posted by Simon Worrall on 22 January 2013 at 05:40
    I have a roland plotter and I am using windows xp with illustrator 10
    I am trying to cut a file sent by a customer, made from outlined text, but the roland keeps cutting each path twice.
    I have gone through the file with the white arrow, dragging all the paths to the side, to see if any are hiding underneath. I am unable to find any other paths.
    Yet when I send it to the plotter, it goes over each letter two times.
    I have drawn boxes myself to see if these are doing the same, but they only cut once.
    WHat has the client done to make the paths cut twice? And how do I find the duplicates and delete them?
    Simon.
    Simon Worrall replied 12 years, 11 months ago 7 Members · 14 Replies
  • 14 Replies
  • NeilRoss
    22 January 2013 at 07:51
    Sounds like it’s got to be duplicates …
    Are the sections you’ve checked by moving possibly grouped (in twos)?
    Is there a duplicate in white that you can’t see?
    Are there few enough segments that you can count by eye. Then select all and see if it tallies with your eye count?
    Neil
  • Harry Cleary
    22 January 2013 at 08:58
    There is a setting in my software (Cutting Master) where you can tick a box to tell the cutter to make two passes, maybe yours has similar?
  • Steve McAdie
    22 January 2013 at 10:21
    Hi Simon,
    I had similar problem to this in the past.
    It is probably being caused by the use of transparencies. One way round it is to flatten the artwork but that can leave a pale box around objects using transparencies. I never get the problem when it is a file generated by illustrator only when it is a customers artwork generated by corel. Thats not to say that corel is doing it wrong or illy is it’s just that they do things differently from one another and this is the result. Get the customer to send file as pdf that should work. It is a very annoying problem that doesn’t always happen and is only noticeable when graphics are in final stage being cut.
  • Glen Mathers
    22 January 2013 at 10:33
    Can you attach the file? see if we can find anything.
  • Nick Eccles
    22 January 2013 at 11:01
    I had a very similar problem (although it was in CD X6) the customer’s artwork had "convert stroke to outline" applied to it, this was then giving me two cut lines…
    I hope this hasn’t confused things further.
    Nick.
  • Simon Worrall
    22 January 2013 at 22:59
    Thanks for the input guys
    Here is the file – if I can get it to attach properly
    Simon
  • Harry Cleary
    22 January 2013 at 23:07
    There’s a duplicate on top Simon when you ungroup.
    Will I sort it and send file back?
  • Simon Worrall
    22 January 2013 at 23:16
    Crikey!
    The ungroup option is greyed out when I open it! Wierd.
    Yes please. Can you repost it here?
  • Harry Cleary
    22 January 2013 at 23:40
    Try this Simon, strange file, only some of it is duplicated. Get back to me if this doesn’t work
  • Simon Worrall
    23 January 2013 at 01:05
    Well that is very wierd indeed Harry. THere is now NO content whatsoever that I can make out in Illy. Nothing at all.
    I am flummoxed. Thanks for your help anyway……
    Simon
  • Harry Cleary
    23 January 2013 at 01:11
    Might have been the way I saved it, try this
  • Tim Painter
    23 January 2013 at 07:15
    I cut direct from Corel using Roland driver if I accidently leave a path filled white it cuts twice, just a thought.
  • Simon Worrall
    23 January 2013 at 08:09
    That’s better. It is all there now!
    Thanks Harry. It is night time here now, so I will do it tomorrow morning when I get to the workshop.
    But now to figure out why I cant see the duplicates!
    Tim, I toggled between Preview and Outline, so any path with a white stroke should have shown up in Outline mode. Nada.
    Simon.
  • Simon Worrall
    29 January 2013 at 20:02
    Apologies, Harry, I forgot to come back to this discussion and let you know how it went. 😮
    It worked just fine that time. Thanks for doing that for me.
    I would still love to know why those paths were invisible to me, yet you could see them.
    Simon.
