Home Forums Vinyl Cutter Discussions General Cutter topics Help on testing a cutter
  • Help on testing a cutter
    Posted by MCS on 28 October 2005 at 11:57
    I was wondering if you guys can help me testing a 2nd hand plotter Ive won on ebay , ill pick it up this weekend its a p-cut plotter .. i need to know if theres a test on the cutter i can do to make sure every thing works OK .. your quick response would be appreciated
    MCS replied 20 years, 2 months ago 2 Members · 2 Replies
  • Peter Shaw
    28 October 2005 at 12:39
    I’m always amused by the way people say they’ve won something on Ebay.
    OK, so you’ve bought a plotter. what’s a P-cut? Is it one of the chinese things? Presumably it will come with some software or you will have programs to drive it.
    To test it send some shapes of known size and cut them out. You can then measure them to check scaling. A rectangle will show the quality of corner cut and a circle should be that, not elliptical. Cut some large and small text, serif and sans serif and look at the cut quality in terms of ease of weeding, square corners etc. Depending on your software, check panel cutting and overlaps to ensure they work.
    If that’s all OK, start earning. If not, start cursing!!
  • MCS
    28 October 2005 at 13:06
    quote pshaw:
    thanks for quick witty reply Pete :lol1: The first test seems simple enough .. cheers
