Home Forums Software Discussions Signlab Software Help Needed Please
  • Help Needed Please
    Posted by Hayley Walker on 10 August 2009 at 14:46
    It’s Hayley again in the Isle of Wight, having a real bad day, really need some assistant, before I go mad and check into The Proiry!!!
    I have a picture that’s’ a jpeg file, Ive tried to convert into a eps through a new version of Corel draw and I cannot import into signlab 5 (old version), some has told me to try an old version of Corel draw not I do not have one, been looking to download but can’t find one, is anyone willing to try and convert so i can use in signlab 5. I have the picture as a jepg and a pdf too.
    Really like some help
    thank you
    Alan Drury replied 16 years, 3 months ago 8 Members · 14 Replies
  • 14 Replies
  • Peter Dee
    10 August 2009 at 16:18
    Why do you need it as an eps to go in to Signlab?
    I’ve tried this and it doesn’t work.
    Are you trying to vectorise it?
  • Hayley Walker
    10 August 2009 at 16:28
    Maybe I don’t need it as a eps but I need some form of file to cut it in signlab at the moment I have it as a jpeg or pdf, no sure what to do, all I want is a picture of some swirly waves simply to cut on vinyl plotter for someone car!!! and it is turning into a nightmare!
  • Lorraine Clinch
    10 August 2009 at 17:12
    Hi Hayley
    Did the file I emailed you not work?
  • Peter Dee
    10 August 2009 at 17:55
    Hayley, it sounds like you are trying to make something more complicated than it is, plus Signlab just can’t do it that way. You would have to import the photo and vectorise it, then pick of the vectors you need.
    A simpler way might be to import the photo, drag a corner to enlarge it a bit, then select the node edit tool and add notes over the top following the lines you are trying to achieve. Join the 2 end nodes together, scale it as required and you will have a solid cuttable vector.
    If you’re still unsure, in Signlab press F1 on the keyboard and go from there.
  • Hayley Walker
    11 August 2009 at 11:05
    Hi Pete,
    I still can’t get this to work, Ive running Signlab ES2 Euro not 5, I have a file that is a pdf, how can import into signlab es2 euro!!
    Thanks Hayley
  • Hayley Walker
    11 August 2009 at 11:11
    quote Lorraine Clinch:
    Hi Hayley
    sorry not just check not signlab 5 signlasb ES2 Euro maybe this makes a difference
  • Lorraine Clinch
    11 August 2009 at 11:15
    Hi Hayley, just sent you another email & .svg file, maybe that will work. Your version of SL is very early, I believe, and is probably the reason why you are having trouble.
    Lorraine
  • Shaun Harris
    11 August 2009 at 12:31
    I have a feeling only signlab 8 will open pdf files.
  • Hayley Walker
    11 August 2009 at 16:48
    quote Shaun Harris:
    Thanks Ive spoke with Signlab I need to convert file through Corel Draw old version as a ai, first I hope that works.
  • Ray Wilcox
    4 September 2009 at 10:51
    Hi Hayley, if you want to be sure of getting the file into Signlab 5.0 have it saved as AI (Illustrator 88 format). All Illustrator versions can save in historical formats.
    4 September 2009 at 11:48
    Do old versions of Illustrator support bit maps? ie if you export a bitmap from Corel as Illustartor 88 you will save part of it as eps and that eps needs to go into SL . If it is a bitmap I would export as tif or jpg and import that. Late version of Illustrator will include the bitmap but may not be supported by SL.
    Alan D
  • Barbara Eden
    4 September 2009 at 12:01
    Hi Hayley
    I have Signlab ES2 :lol1:
    I import jpegs most of the time.
    Then convert to monochrome, trace and Ta-da, you’re done 😀
    Whether that’s the correct way or not though, is another matter 😳
    Barbara
    4 September 2009 at 12:21
    quote Ray Wilcox:
    Welcome to the boards Ray,
    Maybe a little intro in the "say hello" section to tell people a bit about yourself. 😉
    4 September 2009 at 13:15
    Peter, you mean there’s a Signlab user who doesn’t know Ray. 😀
    Alan D
