Home Forums Printing Discussions Uniform Printers help needed , my cadet plus is not printing correctly
  • help needed , my cadet plus is not printing correctly
    Posted by Darren Barratt on 21 August 2012 at 14:00
    hi everyone, i wonder if anyone can help, i have a problem with my uniform cadet plus, its printing a test print ok and it prints the confidence strip nicely but when it prints no matter what resoltion it bands a little and the darker colours like brown and such like printing blochy with like it has dust on the media, this is on any media at all, ive changed the dampers still the same, ive cleaned the heads ect, can anyone help, many thanks
    Stafford Cox replied 13 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
    21 August 2012 at 15:50
    Maybe check the heaters are working?
  • Darren Barratt
    21 August 2012 at 16:37
    hi phil, thanks for the info, i checked and they are both working, i contacted printmax engineer for info and he took me through various things, the conclusion at present is it is the encoder strip as it does have a couple of creases in, £169 +vat from print max, seemed alot for a strip of plastic, any thoughts on suppliers??, also the printmax engineer steve was really helpful, i do normally buy my parts there but it does seem a tad expensive, any thoughts?? maybe im really wrong
    21 August 2012 at 16:53
    You could try digi-print supplies who advertise on the front page?
  • Gary Birch
    21 August 2012 at 19:41
    I would try and turn over the encoder strip… We did this on one of our versacamms about 3 years ago and it is still running strong(touching wood lol)
  • Stafford Cox
    22 August 2012 at 08:16
    Encoder strips are terribly expensive for what they are. You can usually tell when an ecoder strip is faulty as it will cause vertical stepping in your print or cause the carriage to stop at random positions.
    Have you checked the calibrations of the head at all?
    Stafford
  • Darren Barratt
    25 September 2012 at 19:00
    hi, thanks for all the help and advise, i changed the encoder strip and it is printing a whole lot better now but it has not cured another problem i have, basically printing fine , nossle check fine, test print fine, then if i print a pictture of something very black it prints and then after about 12 inches into the print, the black slowly turns to a lighter black/grey, almost like its running out of ink, please can someone help, thanks
  • Stafford Cox
    28 September 2012 at 16:40
    Hmmmm. Could be overinking from your profile? Can you think of anything that’s changed since it last printed nicely?
