Home Forums Sign Making Discussions File Swapping help needed
  • help needed
    Posted by Keith Beckwith on 5 January 2007 at 17:24
    hi folks………
    I have a file I need to get redrawn.
    Does anyone or can anyone recommend where i can get this done?
    I only have corel 9 and I’m not very good with that……a bit slow.
    Hope Ive managed to attach the said file.
    thanks in advance
    Keith
    ps. I promise I will get a photo put up soon……
    David White replied 18 years, 9 months ago 6 Members · 6 Replies
  • Russell Pavey
    5 January 2007 at 17:28
    Hi Keith
    Try Vectorwise on the home page.
    Russ
  • Keith Beckwith
    5 January 2007 at 17:31
    that didn’t work let me change that to a jpg
    sorry folks
    5 January 2007 at 17:32
    Keith, I would try vectorwise as well, I have not used their services myself but have read a lot of posts from members who have and have been delighted with the complete package, price-quality-turnround.
  • Tony Holes
    19 January 2007 at 06:13
    your best bet is to print it out, trace it, and scan it back in. My light box gets plenty of use at my shop. Not the easiest way but sometimes you have to do what you have to do 🙂
  • Graeme Harrold
    19 January 2007 at 10:15
    Learn…. Learn…. Learn…..Convert the file to gray scale and manually trace in Corel Draw. Open up the "Object Manager" and create a new layer. Draw over your logo then delete the underlying logo. Time spent learning Corel will be invaluable in the future as you will not have to pay hefty out-source charges for vectorising graphics. Trace tools are good if you work on "that will do". If quality is one of your selling points then you got to learn…..plus you can add graphic editing fees to your costs.
    For engraving purposes I would manually trace that logo in under 30 mins (outlines only) and charge the customer £15 set up fee and retain the graphic on file. (It doubles if they want to have a copy of the vector file).
    In addition, by creating your own vector files you can build up the graphic in a logical manner (from the cutter/plotters perspective) and speed up the output process. When automatically traced plotter output can be random, producing excessive tool lift operations and extreme movement across the X & Y axis’s
  • David White
    19 January 2007 at 15:25
    vectorwise are brilliant used them many times
