Home Forums Software Discussions Signlab Software Help Importing files into Signlab7
  • Help Importing files into Signlab7
    Posted by Colin Aburrow on 30 January 2011 at 00:06
    Can anyone help.
    I am trying to import files into newly installed Signlab 7 Print & Cut software. For some reason I can’t seem to import any eps, Ai, Pdfs or any other files other than cdl files. Do I have something not switched on correctly or is it just me being a bit thick. I have watched the signlab tutorial and have followed instructions correctly I think but for some reason it is not having any of it.
    Colin
    Peter Normington replied 14 years, 10 months ago 5 Members · 25 Replies
  • 25 Replies
    30 January 2011 at 00:12
    I’m sure there is an import information box which asks which files you would like to use and import, but cant remember where it is sorry not much help, but I’m sure it will jog someone elses memory 😀
  • Colin Aburrow
    30 January 2011 at 00:20
    Hi Nicola
    Yes there is and have selected file types but when I try to place file on the page it comes up with the file name at the top of the screen but nothing appears on screen just blank.
    Got me stumped.
    30 January 2011 at 08:39
    Colin are you using the "import button" or dragging the file onto signlab, either way should work, but you cant "open" other files, which build and version of sl do you have? press help,-about sl, then "r"
    Have you tried placing an eps in the vpm to see if that works?
    30 January 2011 at 10:15
    quote Colin Aburrow:
    That suggests to me that you have succeeded in opening the file – you just can’t see it.
    Try zooming out as it may have imported into an area of the page that is off screen.
    Another possibility is that the image may be painted white and if you are viewing it in colour you will not be able to see it. Change the view to wireframe
    30 January 2011 at 10:20
    good thinking Phill,
    In this case Colin, you could also try the "zoom to selected button" (F7) immediately after importing
  • Colin Aburrow
    30 January 2011 at 11:15
    Hi Peter/Phil
    Its Signlab 7.1 and I have tried many different files and types but its as if Signlab seems to process the file but just doesn’t appear on screen. I have tries zooming right out and tried to select all but nothing. I have just tried to copy from Illustrator and paste into signlab and that seems to work. I must admit its got me a bit stumped.
    Colin
    30 January 2011 at 12:13
    Have you tried a "File open" instead of "File import" to open the file?
  • Colin Aburrow
    30 January 2011 at 12:41
    Hi Phil,
    Yes I have tried that but it will only let me open cdl files. I can see the eps files in the preview window but won’t let me import that way. It’s as if I don’t seem to have something in the setting switched on but I have tried to go through all the setting and they seem correct. I have also tried un-installing and reinstalling but still nothing.
    Colin
    30 January 2011 at 14:14
    Colin
    when you click to import, do you get another dialogue box asking
    which filter to use?
  • Colin Aburrow
    30 January 2011 at 16:51
    Hi Peter,
    Yes it does but even selecting the correct file type it seems to make no difference you get the file name appear at the top of the screen it seems to process the file but nothing appears on screen. I have tied selecting all zooming out as Phil mentioned but nothing. The only way I can get anything other than a cdl file to appear is to copy in Illustrator and paste in Signlab.
    Colin
  • Jason Davies
    30 January 2011 at 16:56
    As a matter of interest which program did you use to save the file as an eps, Illustrator? Corel?
    Jason
    30 January 2011 at 18:01
    try ticking the merge option when you first import the file.
    also have you got any layers at the bottom left, if so try collapsing them
  • Colin Aburrow
    30 January 2011 at 18:51
    Jason it was created & saved in Illustrator CS3.
    Peter I have tried with merge ticked and un-ticked no joy. There is no layer information at the left hand corner. I can see the information as Signlab processing it but once the egg timer has finished the information disappears.
    I can create text & object files in Signlab and save them and then re-open with no problem but any eps,pdf.
    I have just tried jpeg and it works ok 😀 so it seems to only be eps, AI and pdfs. But as most cut vinyl are vector based Illustrator files a bit inconvenient.
    Colin
    30 January 2011 at 19:05
    Colin can you post up one of the files?
    or send me one via email?
    peter
  • Colin Aburrow
    30 January 2011 at 19:30
    I get file name & files of type. I have tried using the correct filter.
    Colin
    30 January 2011 at 19:46
    Colin,
    Are you new to signlab, or is this a problem that has just started,
    I only ask because SL7 is quite old now, and I am wondering if you have a mickey mouse version? I dont mean that in a bad way, because you could have bought it included with some equipment etc. do you have a dongle?
    30 January 2011 at 19:59
    colin
    your file opens for me, but it is only 11mm square!
    is your signblank turned on?
    if so it should open in the bottom left corner
    give me a few mins i will look further
  • Colin Aburrow
    30 January 2011 at 20:07
    It came pre-loaded with an laptop & old cutter I bought a few years ago from bankrupt business but haven’t used since. Laptop is defunct so have just loaded to new pc. I have backup disk and serial no but there was no dongle. I have just bought a new Summacut 1400 which did come with winplot but thought that Signlab would be a better operating package to use after reading some of the post on here.
    Colin
  • Colin Aburrow
    30 January 2011 at 20:08
    Peter I had to reduce size to post due to min 400kb
    30 January 2011 at 20:18
    Colin there are 4 stars in the image, they have a very thick line, so I think because the image is so small it is having a confusing effect, I can open the file in corel, and illustrator and in wireframe it is fine, it is also ok in signlab, but before enlarging you would need to make the line Hairline otherwise you will have unusall results
    I have re-sized the file in signlab so try this and let me know the results
    30 January 2011 at 20:19
    Colin if you dont have a dongle its a cracked or demo copy. so that could be where the problem lies 🙁
  • Colin Aburrow
    30 January 2011 at 20:31
    Peter the file you sent over loaded fine?? Don’t understand what did you do?
    Colin
    30 January 2011 at 21:36
    Colin, I just zoomed in on it, selected the "stars" changed the outline to a hairline and enlarged, an eps vector file should not change in size, no matter how big it is in dimensions.
  • Colin Aburrow
    30 January 2011 at 21:57
    Peter I have just tried back saving a few different files to legacy ver.3 and all loaded ok. Is this what I have been doing wrong or should I be able to load any CS3 AI or eps. Sorry it sounds like a silly question but just trying to learn & understand as this type of work and programs is still very new to me.
    Thank you for all the help time and patience you have taken with me.
    Colin
    30 January 2011 at 22:22
    may be the case Colin,
    I opended the files in SL 8 and 9,
    but they may not be compatible with signlab 7
