Home Forums Vinyl Cutter Discussions General Cutter topics Help! I’m Going Crazy!!!!!!
  • Help! I’m Going Crazy!!!!!!
    Posted by Pedro on 19 August 2004 at 12:46
    I need help! I’ve got a Mutoh MC-650 S Plotter which has developed a mind of its own and has started playing up. Does anybody know of anyone who could fix it for me? I’m in Lancashire. Any help would be Fantastic! It’s starting to feed off all by itself and spooling vinyl all over the place. (<(
    Colin Crow replied 21 years, 3 months ago 1 Member · 1 Reply
  • 1 Reply
  • Colin Crow
    22 August 2004 at 21:45
    Sounds like a similar problem I have had with my SC650. It could be the front sensor faulty or loose. Check the small led on the cutting bed about 250mm from right hand side. It should be lit when working (dimly) and detects the front edge when measuring the vinyl. If not the vinyl just keeps rolling of until the end! I could cure mine temporarily by tapping directly on the bed over the sensor. It took the engineer loads of attempts to find the faulty cable and solve it though. Mutoh will do servicing direct, but ours is covered by contract. If you email me I will get the details of the repair company from the file. I know they work direct because they always try to charge me on each visit.
