• HELP – I hate PC’s
    Posted by Jason Davies on 5 June 2009 at 17:10
    Very frustrating, the only PC we run is a Toshiba Satellite Pro which powers up our gerber etc, unfortunately it is giving me this message:
    PXE-E61: Media test failure, check cable
    PXE-M0F: Exiting PXE ROM
    Any suggestions how I can sort this out, I have hone into the BIOS and there does not seem to be a hard disk mounted.
    Out of interest anyone run a gerber and cutter from a modern iMAC maybe time to change, however I would like to get this running asap as I have a big job due out on Monday.
    Jason
    Jason Davies replied 16 years, 6 months ago 7 Members · 9 Replies
  • 9 Replies
  • Kevin Flowers
    5 June 2009 at 17:15
    Jason
    can’t actually help but if you punch them codes in to google hundreds of replies about what you are saying might just help you
  • Jason Davies
    5 June 2009 at 18:00
    Tried that Kev, thanks though.
    Jason
  • Mathew Gibson
    10 June 2009 at 11:39
    Buy a Mac????
  • John Wilson
    10 June 2009 at 12:13
    Is this the laptop? i have a toshiba satellite laptop and had that problem in the past
    Funny enough I never fixed it and it just worked the next day strangely enough
    Apparently flexi sign is a really good bit of software on a mac for running cutters/plotters
  • Joseph Helm
    10 June 2009 at 12:25
    quote Jason Davies:
    It’s trying to use the boot sequence (1. HDD 2.CD 3.Network)
    As it can’t find the first few, it’s tying to boot from the network.
    If it’s not showing up the HDD, open the case and unplug it.
    Also unplug USB leads, Network cable etc
    Boot up, once it gives you an error about no hard drive, shut down.
    Plug the HDD back in, and boot up… (works 80% of the time for me)
    If that fails, go in to the bios and revert the bios settings back to default.
    And try that.
    If you still get the error, then it sounds like a hard drive failiure 🙁
    Hope it helps
    Joe
  • Cheryl Smith
    10 June 2009 at 17:04
    I just had to have the hard drive replaced on my one of these. Im glad i bought the 3 years business next day repair plan as extra.
    10 June 2009 at 17:07
    im thinking hard drive failure… google tells me the error message is longer then that
  • Jason Davies
    10 June 2009 at 21:06
    Thanks guys, worked after about three days and has gone again, will drop it off to one of the engineers tomorrow.
    Matthew, this is our only work PC, just kept on the side to run Omega, we are completely MAC based fortunately.
  • Jason Davies
    23 June 2009 at 12:06
    Just a quick update, thanks for all the help. The laptop is now in the bin and we have upgraded with a new PC, also upgraded to Omega 3.0 as the usb to parallel would not drive our Edge without the upgrade. All good stuff though.
    Jason
