Home › Forums › Sign Making Discussions › File Swapping › Help – How Can i…..
Help – How Can i…..
Posted by siroccomanuk on 23 March 2008 at 11:58Get rid of all the crap on the outside of this ‘ripped’ design?
siroccomanuk replied 17 years, 9 months ago 4 Members · 14 Replies -
Wel, it was made in Signlab 7?
Have attached it in.ai format (as you may be able to tell, I only dabble in this stuff – and wish i never got involved!
bit of a mess that one dont think i would bother just print it
Hi – yes I agree total mess 🙁 it wastes so much media each time though!
Thanks for your thoughts anyhow.
Dawn
not sure if this is what you meant
But I deleted all thewhite squares and then used the cut path as a clipping path In siglab you will only see the whole thing with fill turned off
Peter – you are a STAR that is JUST how I wanted it 😀 😛 Thanks also for your help Steve, but not quite what I Wanted.
Just ONE other question? How can I make a complete REVERSE of it so wording stays the same but so the whole thing faces the opposite way? 😕
In SL you’ll find the mirror option on the layout menu, however the text will need to copied from original and re-positioned.
Are you using SignLab?
Steve -
Hi – Yes I am using Signlab 7 – I can mirror it OK but cannot sort out the text 🙁
here is a tidier version, of the two, l I ungrouped, deleted all the white squares, welded and then deleted all the shapes on the outside
Peter, You are an absolute Angel (angel) I owe you one BIG TIME 😀
Thank YOU SO MUCH,:love:
Peter – Sorry to be a pain, but froggies bum is hanging out of the bottom of the left rip? and his arm is as well? Can I get rid of this?
You are and even bigger (angel) now – You have actually taught me how to do something (<( without me :banghead:
Thank you so much.Dawn
