Home Forums Software Discussions Corel Software Help – Corel X4 Increasing text size over 3000 points
  • Help – Corel X4 Increasing text size over 3000 points
    Posted by Praveen Jayawardene on 27 February 2010 at 00:11
    Hello All,
    Hope all is well in Corel World !
    I have a silly question that may have an easy answer.
    I am currently creating some wording in Corel for a large sign.
    I am currently using Corel Draw X4 and i am trying to increase a font size over 3000 points.The font type is Bell Mt .
    I just cant get Corel draw to allow me increase the sizing over 3000 points.Is there a default setting in the back end that can be changed ? or is it something i am doing wrong ? I tried with the resizing tool and also by trying to change the figures in the points size box with no luck.I also tried with another font type with no luck.
    Any help would be appreciated,
    Cheers,
    PJ
    David Rowland replied 15 years, 10 months ago 5 Members · 5 Replies
    27 February 2010 at 00:17
    never hit the problem but i would convert to curves and try that
  • Praveen Jayawardene
    27 February 2010 at 00:28
    Thanks for the quick response !
    Yes Chris it’s weird ! I will take your advice to see things through.
    Will be interested to see if any other user has come across this issue in the past.
    Appreciate your advice,
    Cheers,
    PJ
  • Andy Gorman
    27 February 2010 at 01:20
    Yes, I’ve had that happen with certain fonts. As Chris says, convert to curves first.
    (I never trust the point sizes that Coreldraw says anyway.)
    27 February 2010 at 14:00
    3000 is the limit. As Chris said convert to curves. Corel uses the normal typographical way of sizing fonts ie it takes into consideration ascenders and decenders so a H set at say 50mm won’t be 50mm if cut, several workrounds but I use the Autosize macro from Macromonster. It won’t help for text over 3000pt but you can get the cap height right, same macro for straightening objects or images.
    Alan D
    27 February 2010 at 14:18
    might actually be a windows limit tbh
