Home Forums Sign Making Discussions Vinyl Help and advice with Contravison please?
  • Help and advice with Contravison please?
    Posted by Leon Winslade on 4 May 2012 at 15:10
    I have a issue with it pealing away from some glass I have not got an issue with water as it is protected. I have a Sealitpen which I going to try on it does any one Else have any Ideas (:)
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Some things HERE you may wish to think about.
    Please take a moment to look over our Board Rules.
    Stuart Taylor replied 13 years, 5 months ago 4 Members · 4 Replies
    4 May 2012 at 15:46
    with amari contra-look-a-like… i found water was too much for it, attacks the adhesive too much.
    apply dry was better
    however the bit that was on our own door, after time it stuck better as it dried out.
  • Richard Urquhart
    7 May 2012 at 20:53
    try this NANO EX
    http://www.jagsignsupplies.com/aqshop/c … hp?id=1931
  • Denise Goodfellow
    7 May 2012 at 21:02
    We bought some from RH, didn`t bother to lam or seal it as it was a tester on my step sons hatch,
    Its still as good as it was 12 months later…. well pleased with the material
  • Stuart Taylor
    8 May 2012 at 13:18
    Hi Leon
    Is this actually Contravision or is it another manufacturers version of the product ? If it is Contravision do you know which laminate has been used ? We carry 3 different versions of laminate to use with the Contravision Performance range – a polyester, a cast and a polymeric version – each of these products would perform differently depending if the product is applied inside or out and if it is applied to flat glass or curved glass (such as the rear window of a cab)
    As Dave has stated Contravision should always be applied dry especially if laminated (otherwise you just trap the water in the perforations)
    A Sealit pen will not help edge seal a product construction such as this as the Sealit pen doesn’t give a thick enough edge seal, however a physical vinyl seal would help as an additional taped edging overlapping the Contravision and glass by 3 to 5mm ….. Unfortunately I don’t think this will help seal an already failing application as the adhesive will almost certainly be already damaged and water/dirt ingress will have effected the reverse of the laminate if it has lifted.
    If you reply regarding the product used, application method and description of glass it was applied to (or add a photo of the faiure) I will see if I can help with a solution.
