Home Forums Sign Making Discussions General Sign Topics heavy material for exterior sign
  • heavy material for exterior sign
    Posted by John McNickle on 19 September 2012 at 18:05
    Hi i am looking at ajob for a funeral director and he wants it to look like granite gravestone material, then i will be routering out the name etc and inlaying with silver or gold, i was just hoping you guys would know of a good material to use 🙂 i can get Corian from a friend and it would be the best job but it is crazy money for the size i need 🙁 i dont think he would go with 19mm foam painted and heave perspex is mega bucks too
    Harry Cleary replied 13 years ago 5 Members · 12 Replies
  • 12 Replies
  • John McNickle
    19 September 2012 at 18:06
    sorry the sign will be 16ft X 3ft
    19 September 2012 at 18:58
    My thoughts are to find a suitable textured vinyl to use to wrap a panel with in order to create a granite like finish.
    Maybe something in the grafityp range of films?
    http://www.grafityp.co.uk/automotive-fi … fects.html
  • John McNickle
    20 September 2012 at 07:19
    cheers for getting back Phil, i had thought about doing this but i was a bit concerned about the vinyl still looking good in a few years, i know it would have 5 yrs at least but a good panel with its own finish will always win, its still a very big option at the moment
  • Sam Armstrong
    20 September 2012 at 09:30
    Many years ago I came across a product I believe called sign rock but at that time was only available in 4 x 2 sheets upto 50nm deep I recall, it did have a high cost though but could router and engrave into it.
    However, if you think foam painted is too expensive this wouldn’t work but a great material when finished.
    Sam
  • John McNickle
    20 September 2012 at 09:34
    Sam ive just had a supplier on with me about a product call signblock and it looks the job, its pricey but not too bad and it only comes 4′ X 4′ but can butt together nice, it is also nice and light but looks heavy so there is a win point.. if i get the job and go with this ill put a few pics up
  • Sam Armstrong
    20 September 2012 at 09:38
    Hi John, that is great news, would very much like to see how it work outs for you, presume you can router this material as per sign rock – I do remember like most porous products it may take a lot of finishing but worth it for the end result.
    Keep me posted as I am interested?
  • John McNickle
    20 September 2012 at 11:08
    ummm just got a quote in on the sign block for the size i need in 50mm board with primer and glue etc its coming in at just under £1000 😮 😮 this is for supply only and then my time for machining, Prep and paint then fitting.. i can see why the other guys arent stocking it much 🙁
  • Harry Cleary
    20 September 2012 at 11:49
    Exterior Medite, run a frame on the back, fill all the edges so it looks solid and correct thickness, router the letters, then have a faux paint/paint effects specialist put a fake marble finish on it. Fill lettering with gold etc. Apply 3 to 4 coats of sprayed exterior varnish.
    Bit of work, but with a good effects painter, would look the part.
  • Harry Cleary
    20 September 2012 at 11:53
    Material Sam was referring to was SignRoc, or HDU foam.Expensive but a great material for carving and finishing. I finished it in waterbased paints and it lasted for years. Has a texture though, so might not be suitable for a faux marble finish.
    I got it in Dublin, I can look up the supplier if you want, it was at least 10 yrs ago though.
  • Tim Painter
    20 September 2012 at 12:16
    John how deep do you need to route?
    I would still of though Corian was suitable mounted on to some sort of backing.
    I believe you can get 6mm , 12.5mm & 19mm.
  • John McNickle
    20 September 2012 at 15:02
    Cheers Harry and Tim for getting involved, Harry if there was a supplier this side of the water it might help, worth a try anyway as im just outside belfast, the delivery on 4 4’X4′ sheets from england was £80 + VAT 😮
    Tim i can still use corian but its about £1500 at the least and thats before machining and inlays, fitting etc 🙁
  • Harry Cleary
    20 September 2012 at 16:41
    It was definately these guys John, http://trimwel.ie/index.php?page=home
    Had a quick look at the website but I don’t see it. Might be worth a ring.
