Home Forums Printing Discussions Sublimation Printing Head Cleaning.
  • Head Cleaning.
    Posted by Earl Smith on 4 July 2008 at 13:51
    I`ve recently bought an Epson Stylus Photo 1400 with a sublimation bulk ink system setup. I use it nearly every day and found it to give excellent prints.
    Nearly every time before I use the printer I have to do a Head clean because one of the colours are not coming through.
    Am I damaging the machine by these repeated daily head cleans?
    Earl
    Earl Smith replied 17 years, 5 months ago 3 Members · 5 Replies
  • John Thomson
    4 July 2008 at 14:21
    Heads cleaning should not damage the print head as far as I know……but it does use/waste a lot of ink.
    A head clean everyday seems excessive.is it always the same colour?
  • Earl Smith
    4 July 2008 at 15:14
    Hi John,
    Yes it seems to be the cyan or light cyan. But it could be all of them . The print comes out a little reder than it should.
    I had a thought after I made the post. The printer is turned off over night. Maybe if I leave it on the print head will stay warm and the ink wont dry.
    Earl
  • John Thomson
    4 July 2008 at 21:54
    I always print a nozzle check before I print…saves waiting ink and possibly blanks….this will also tell you exactly which colour is giving you a problem.
    Strange as the only times I have had to do a head cyan it was Cyan that was not firing cleanly.
    I know that when you switch on the printer does a self test which uses ink.
  • Simon Polakof
    5 July 2008 at 13:35
    Hi!
    Have you profiled your printing substrate or using the correct profile? If you haven’t then these might be the answer to your troubles my friend.
  • Earl Smith
    15 July 2008 at 13:23
    Thanks for the advice. Its the cyan that wasnt fireing cleanly. The last week I have used the printer and all is well. All guns fireing. I have done nothing to the printer except use it 2 or 3 times a day. Maybe its because the printer is new and needed running in.
    The profile and inks are correct. Sawgrass. so should be ok.
    Prints beautifully. Really strong colours.
    Thanks Earl
