Home › Forums › Printing Discussions › Roland Printers › Head bumping on the right hand side – Versacamm VP300 help
Posted by Paul.Gadsdon on 8 May 2014 at 15:29Hi
I have noticed that thee is a slight bump when the head returns to the right-hand side of its carriage, its not load just a little bump but it is enought to make the printer wobble a little
I have undertaken a limit calibration last night but still the problem exists
Any ideas
Paul.Gadsdon replied 8 years, 6 months ago 5 Members · 23 Replies -
quote Kevin Flowers:Hi
would help if you said what machine it wasKev
Soz, its versacamm vp300
Sounds like it needs the flushing position setting correctly
quote Julian Mildner:Sounds like it needs the flushing position setting correctly
Flushing position? what is that as i have set the limit on it
There is a setting to adjust how far right that the head travels during printing.
It needs to travel far enough to be above the caps so that when it does a spit, it lands in the caps but not too far right that it hits the capping post on the capping station. If it is set too far to the right, it will hit the capping station on every pass causing the bumping sound. -
Right
Is that not called limit initialization?? If so I have done this, seems that I might have to do it again
Right well I need to get to the service menu to do this and I dont know the code, I have used left, right, up and power bur it says that the "service menu is protected"
Anyone know what the code is for a VP300?
Backwards ‘S’, backwards ‘V’.
Down, right, left, up, then down, left and right at the same time and power on.
[quote="Stafford Cox"]Backwards ‘S’, back wards ‘V’.
Thanks for your help but what does backwards ‘S’, back wards ‘V’ mean?
Oh yes I know what you mean now, will give it a go
Many Many Thanks
quote Paul.Gadsdon:quote Stafford Cox:Backwards ‘S’, back wards ‘V’.
Is this with the sub power on or off?
Bump
As I have been unable to get into the sevice menu
I was working on an older Roland SC today and the service mode pattern is different. Try one of these two:
Up, left, right, down, left, right, down, then hold left, right and down and power on.
Up, left, right, down, left, down, right, then hold left, right and down and power on.I think it’s the second one.
Stafford
quote Stafford Cox:I was working on an older Roland SC today and the service mode pattern is different. Try one of these two:
Stafford
Thanks I will try both but is this with the sub power on or off?
Main power on, sub power off. Key in the magic pattern of arrows then sub power on with the bottom 3 buttons held in. Don’t forget to stand on one leg with a light westerly breeze blowing outside :lol1: :lol1: :lol1:
With the left nipple out whilst being sprayed with soda from an antique soda thing
😮 :lol1: (:) 😎
Try Down, right, left, up, then press and hold right down left power on.
quote Steve McAdie:Try Down, right, left, up, then press and hold right down left power on.
Yay!
Points to you sire as your method worked and I have now fixed the head bumping
Now to fix all the other issues I have
Paul 😛 😛
quote Paul.Gadsdon:quote Steve McAdie:Try Down, right, left, up, then press and hold right down left power on.
Yay!
Paul 😛 😛
Thats odd this used to work, does anyone know why it wouldnt now? I dont remember updating the firmware but have reinstalled versaworks on a few occasions
