Home Forums Vinyl Cutter Discussions Mimaki Cutters Having trouble with printing
  • Having trouble with printing
    Posted by Josh Steenbergen on 22 December 2011 at 14:14
    I noticed the other day that my printing is getting a little out.. I checked the encoder strip and it is out about 1mm or less.. I was told that was ok..I was wanting to know out and where to go to check the alignment of the print-head..I am not sure if that is the problem but I cant seem to find where to run the test for the alignment for it..If I could get help with this that would be great..I included some pics of it not a crisp pic.. I had the black print-head replaced awhile ago and I just think they didn’t do a very good job aligning print-heads. or is it something else. Can it be over saturation..if so is there a setting on the printer that I can change to compensate for it or so I just have to change the color values in photoshop..
    thanks in advance
    Stafford Cox replied 14 years ago 4 Members · 6 Replies
    22 December 2011 at 16:55
    what type of printer and has the temp dropped a lot where you are
  • Josh Steenbergen
    22 December 2011 at 19:17
    quote Chris Wool:
    Sorry it took me so long…It is a mimaki JV3 160sp wide format printer.
    The temp is cooler than in the summer but I would not think it would have change my print that much…Its been around 40 to 60 here in indy… Been raining so it not dry yet lol..But I did for get about humidity and temp change..usually when that happens I just have problems with banding not registration..
    thanks in advance
    22 December 2011 at 19:24
    roland man myself so don’t know about that machine.
    temp changes through the year make a difference so you may have a environmental check plus have you had a head strike. normally you can see in a head print check if they are out of alignment.
  • Josh Steenbergen
    22 December 2011 at 19:40
    quote Chris Wool:
    I’m trying to find out how to get to that to find out if the print heads are out of alignment…I just don’t remember why I don’t do it all the time how and where to run the test for the print head Alignment..When it did that before it was the encoder strip but I checked that and ran the test on it…but it checked out good..No I have not had a head strike…I just think the tech that did the alighnment did a half ass job… Thats why I was wanting to check the alignment..
    thx
    28 December 2011 at 01:18
    that last photo is blurr’d.. is that camera or bleeding ink?
    top photo shows what looks like head height is set to high and not low.
  • Stafford Cox
    5 January 2012 at 15:58
    First test to run is the Print Adjust in the Maintenance menu. If that doesn’t do any good then it’s a case of going into engineers mode and running the slant, Y base and print adjust2 calibrations. Can you print just an empty square or rectangle and post it here to see?
