Home › Forums › Software Discussions › Signlab Software › Having problems with sign lab7 dont let me print over 2m Signlab Software Having problems with sign lab7 dont let me print over 2m Posted by asus on 2 October 2006 at 13:46 I have a uniform cadet and for some reason sign lab 7 don’t let me print over 2m, would any one know what i am doing wrong here? Rod Young replied 19 years, 2 months ago 3 Members · 3 Replies 3 Replies Ian Higgins Member 2 October 2006 at 13:58 Hi, In the RiP check what the printer and cutter madia lenghts are set at. Also check it is set to roll and not sheet. Cheers Ian asus Member 2 October 2006 at 14:04 ive did that ian, still no luck 😥 Rod Young Member 4 October 2006 at 18:21 quote asus: I have a uniform cadet and for some reason sign lab 7 don’t let me print over 2m, would any one know what i am doing wrong here? For fast support, I would recommend contacting the CADlink UK Tech Support. In the meantime, it would be worthwhile to check the following: Go File menu >> Print and Cut Setup. The Print and Cut Setup dialog will default to the Printer tab. Click the Page Setup tab and confirm the page/roll settings. If using a roll, then check the Roll Length. Click the Cutter tab. Click Setup to open the Plotter Setup dialog. Verify that the Machine Limits (Length and Width) are set correctly. Regards, Rod at CADlink Log In to Reply Log in to reply. Public All Members My Connections Only Me PublicAll MembersMy ConnectionsOnly Me Public All Members My Connections Only Me Log In to Reply Start of Discussion 0 of 0 replies June 2018 Now
