Having problems releasing vinyl from backing paper
Hi all,
recently i have been having problems with getting vinyl to release from the backing paper, could this be due to the cold weather?, should i be storing vinyl and application tape in a warmer environment? I notice the vinyl is brittle too and tears easy from the cold.
Im also using a new batch of application tape, i normally use medium tack and its fine normally, unless they sent me a low tack batch by mistake!
thanks Brian.
