having backing paper problems with Imageperfect 5700 Series
Hi All,
I’ve been using Avery 500/600 series vinyl but was recommended to try the Imageperfect stuff. I was in need of a colour so purchased a roll of the ImagePerfect 5700 stuff. Seems good quality. Although I am having problems with it. The backing paper seems to have a lot more of a ‘waxy’ coating on it and thus results in it slipping the odd bit in my cutter.
The problem occurs more with larger jobs for the likes of vehicle livery. There has been no problem cutting smaller sizes of say 400mm. But anything bigger seems to slip in the cutter. I’ve reduced the speed of the cutter to see if that helps, which it does but only slightly.
I’m just wondering is it something I’m doing wrong? The clamps are down to hold the vinyl in place and there is no problem with the Avery stuff.
Any suggestions would be gratefully received.
Jonny
