Home Forums Sign Making Discussions CNC Router and Engraving has anyone tried vectorization for engraving?
  • has anyone tried vectorization for engraving?
    Posted by Paul Lowry on 2 August 2003 at 00:22
    Hello, I’ve been looking for a way to replicate images on a rotary engraver. (I currently use a pacer machine). I would like to achive ‘gray shading’. I was toying with the idea of various types of cross hatching to replicates different shades.
    Has anyone out there tried anything like this before?
    Any ideas would be much appriciated.
    Paul Lowry replied 22 years, 2 months ago 2 Members · 2 Replies
  • Rodney Gold
    2 August 2003 at 01:36
    You can use packages like Signlab which have a various methods of scanning that produce “photo” output from images , you could also redraw the image and use hatch patterns from AutoCad or use various densities of a dot pattern to simulate halftones.
    It is possible , but it is not easy as you have to work out what spacing you need vs your bit width and considering that your bit would generally be at least .2-.5mm , your resolution would not be that great , IE the halftone pattern would be quite gross.
    The thing is that you have “one colour” when engraving , engraved or not.
    Thus to represent , lets say 16 shades of grey , you need a “cell” that is at least 4×4 the bit tip width , cos to represent black , you would engrave the whole 4×4 and all adjacent “cells” which will give a solid black
    To represent the lightest shade , one would only engrave a single dot in the 4×4 cell as well as doing the same for adjacent ones. Much like how newspaper pictures work.
    Prior to us using a laser to do this (a laser engraver acts like a printer in that it engraves “dots” as well as doing vector type stuff) I did a few pictures using AutoCad and various hatch patterns , they looked ok , but not fantastic and took a hell of a lot of design work.
  • Paul Lowry
    2 August 2003 at 09:07
    THanks for the advice. I might have a play with this and see what happens. I’ll post the results
