Home › Forums › Sign Making Discussions › General Sign Topics › has anyone heard of the material flexiboard?
Posted by James Martin on 3 April 2008 at 16:09Hi,
customer is looking for 3 foot by 4 foot menus for the inside of a curved staircase wall, he wants 6 of them,(must be some staircase) and he has heard of something called FLEXIBOARD.Anyone heard of this or anything that I could apply vinyl to and then it could be fastened to the wall taking its shape.
Mark Latchford replied 17 years, 8 months ago 9 Members · 16 Replies -
I don’t know what flexiboard is, but I have seen a wooden sheet that has loads of grooves in the back which enables it to bend easily. Maybe that’s what he’s on about.
How curvy is the wall? Could you just use a bendy plastic, like 3mm foamex?
I’ve never even handled 3mm foamex, is it quite flexible?
Bendy plastic sounds about right although I could imagine it being thinner than 3 mm even.
Is the front of the wooden stuff able to take the old vinyl?
If it was A4 size I would just apply letters to the inside of a laminate pouch and seal it up.
Could try HIPPS or Staufen which starts at about 450 Microns thick.
A search for staufen board has led me to a site that explains what it is and it looks OK.
The same site has polypropylene board which looks even better.
tks.
whats is HIPPS then? -
HIPS (High Impact Polystyrene)
comes in sheets 3’x2′
approx 2-3mm thick
colours are normally primary colours + black and white -
europoint do a 900 micron board like HIPS, flexible, strong & lite nice gloss white finish 1250mm x 1500mm. I use it a lot for safety signsKev
Europoint are sending me some samples of Penta.
tks everybody.
James,
don’t know what Europoint is like down your way but could not get samples of this product, something to do with the actual supplier. Eventually had a pack sent out on a sale or return basis.Kev
I’ve used priplak before, very plyable and available in different colours and large sizes. It might be a problem to print or stick vinyl onto though. If I remember correctly it has been through a treatment called corona discharge where its bombarded with electons to change its molecular structure. Don’t know why. :lol1:
The only ink we got to stick to it was coat’s correx ink, mind you, when it did key on you couldn’t shift it.I’ve got some small white offcuts if you need a sample
priplak is semi rigid and takes vinyl fine, available in various microns and some sparkly colours
designed a hot foil and deboss job on a creased menu….worked well…and the foil doesn’t scratch off easily.
used a lot in fold over swatch book type things.. 😀
Hi Andrew,
The keying of ink I mentioned was for car roof top swing signs we printed by the 1000’s for the likes of ford and vauxhall. We tried Sericols version of ink that was meant for polypropylene with no luck – coat’s ink was the only one to key and put up with my test scratch :lol1:Data sheet for priplak: http://www.priplak.com/en/sommaire.htm
Enhancement with printing techniques
CORONA TREATMENT FOR BETTER PRINT QUALITY
PRIPLAK® sheets are treated on both sides, with an electric arc that oxidises the surface of the material.
This fine invisible layer improves the adhesion of inks suitable for printing on polypropyleneI think the treatment wears off after 6 months or so and this could be why we struggled to key the ink.
Cheers John
Cheers John….I’ll be perfectly honest I was so surprised when the foil didn’t rub off………thanks for the info about inks I know someone wanting to screen it for a flyer (?)
Sorry Andrew, should have typed coates inks as the supplier, missed the e, must be the tonic in me gin. :lol1:
Flexiboard is like Correx bit is split down the grooves on one side only making it really flexible. You can easily mount digital prints or screenprint
direct to the substrate I’ve made a few plinths from it. If you ring Amari
they can get hold of it. Comes in various colours as well.
