Home Forums Sign Making Discussions Neon, LED, Lighting Halo Lit Built Ups, Matt or Gloss laminate
  • Halo Lit Built Ups, Matt or Gloss laminate
    Posted by David Hammond on 4 July 2017 at 13:10
    We’re producing a sign for a customer, with built up letters, with LED halo illumination.
    The back board is mainly white, with an abstract background, I’m not sure whether a gloss or matt laminate would be best to diffuse the light on the backboard?
    David Hammond replied 8 years, 5 months ago 5 Members · 6 Replies
  • Jon Marshall
    4 July 2017 at 14:19
    I would go matt or satin
  • Martin Cole
    4 July 2017 at 16:12
    gloss should be avoided as will create spotting with the leds
    4 July 2017 at 16:40
    I thought Matt, but its our first Halo sign so thought I best check!
    Quite looking forward to it!
  • Jasper McEwan
    5 July 2017 at 08:22
    Looking forward to seeing some pictures Dave :thumbsup:
  • Vince Francis
    6 July 2017 at 11:50
    Go for matt, gloss shows up everything if the LEDs are pointed to the panel, if the inside of the letters are sprayed white and you point the LEDs into the letter, then spotting is not an issue. Hope that helps
    6 July 2017 at 13:46
    Matt laminate it is, panels will be mounted Monday, but the letters aren’t due for another week.
