Home › Forums › Sign Making Discussions › Gallery › halo lit blue l.e.d sign: steelpoint tatoo
Posted by Richard Urquhart on 27 November 2006 at 19:01hi all been working on my first stainless steel built up lettering job with halo illumination
fitted today and all when very well the shop front is years old and not an easy fit
big thanks to my mate for his unpaid help
thanks mate !!the grey text outline was used as a must as black will not show the halo and the customer wanted black dibond
Emran Shaikh replied 18 years, 12 months ago 13 Members · 28 Replies -
Good Stuff Rich, nicely done. Just having a play around with my first illumated sign myself now, using Andy’s demo.
Quick question though for yours. When assembly the stainless to the clear letter, do you use any sort of sealant to stop water ingress? or is this not necessary?
Cheers mate :lol1:
no sealent used on mine mate i would think only a very small amount would get in the back of the letter but as they would be damp i did go for the soldered joint and heat shrink so as not to have to go back for a dry joint and most important behind the tray
just found this photo of the shop when i first went to look at it
if you look to the right of the glass at the top you can see how far the frame is out making setting the frame work harder for me when fitting .
The customer wanted the sign to try to make the window frame look correct
not a nice one !! -
Congratulations M8
For the other readers of this post I popped in to Rich on Friday and saw this sign before it went up and It looked fantastic even on the workshop floor, I’m sure it looks better in place tho I haven’t seen it yet
P’s how was your Xmas party M8? (for the benefit of other readers Rich blagged an invite with the adjacent garage’s Xmas party!)
thanks mate
blagged you say !!!!
so true
great do mate right up until the b52s started after that its a blurrrrrrrrrr
sign looks great rich…
as much as i dont like having a halo of vinyl on the backing board to help the spread of light its not really an option. you just have to do "something" or the result is cak! i know, ive done it and although the sign looked great, at night mine was bad. the customer still loved it but for me it was bad. i had a brown backing to the sign with white halo. the halo had no spread so just looked like a stark light on the backing board.
i had defuser plastic in the back but still you could see the odd spotting from the LED’s as a result of the board colour.i know you used ashby led’s in this… how did you find them to work with?
do you see yourself doing more of this type of signage now you have a taste for led work mate?
Nice one Richyboy. I wish some of my muppets…..erm customers would dig a bit deeper for something like that. Looks good.
That is brilliant Rich, really bright too.
Well done.
hi Rich
that sign looks really good very clean and bright.
Being new to this i would not know how to make something like that . Did you buy all the parts separately or does it come as kit.
What sort of price would this kind of sign cost a customer.
Lee -
hi
thanks for commentsthis job was not a great one for earning money it was a learning job and after materials there was not enough in it ,but that was my down to me .
I loved making the sign and i think i have another customer from this job but i have priced this one with every last part in need .as for ashbys leds there great
I’m tempted to print before and after pictures of this lot to show folks around here the value of good, professional signage! Before: Seedy tattoo parlour type place. After: A full wax and massage please, never mind the bill!
On a similar point – I’ve had the idea of illuminated signs next to local highways countrywide. Only problem – there is no electricity, the power lines and trunk roads dont normally follow the same route. Even if they did, you’d have to inslall transformers etc. to step down the (10 000 Volt ?) main lines. I wondered if it’s possible to build the lightbox, iluuminate (internally) with LED’s, and charge a Ni-Cad battery off a solar panel? Anyone tried this?
Very snazzy Richard! We did some similar signs recently, but for indoors. They had brushed stainless returns and polished faces – looked brilliant. We had plently of leds inside to avoid spotting.
There were some problems – basically the supplier (we subbed out the manufacture). One of the signs was a brushed stainless box with neon lights inside, then cut-outs bolder than the 3D letters. The cutouts had diffuser acrylic all over so the ligh shone from the box on to the back of the letters. Our supplier – who shall be nameless I suppose – cocked up 2 factors. 1. he fitted one of the letters askew and 2. he didn’t leave enough gap between the box and the letters although I gave him detailed drawings. So we had to take it down and get it sorted.
The other unit was much better – 3D letters on locators with leds in the letters shining back on a white wall. The transformer was up in the suspended roof with the wire chased into the wall so you didn’t see it.
Pics attached. I’d love to experiment with leds more – just don’t seem to get the spare time! -
That’s really nice Richard. We’re doing a tray sign with the same type of letter and illumination at the moment. I’m having the tray powder coated matt finish to avoid spotting, but somebody also told me that if you do the cut outs in opal frost this diffuses the led light, but is considerably less noticeable by day. The tray we’re doing needs to span a gap of 6500mm, so it will be on a steel framework. I will post piccys, we’re hoping to install before Christmas, weather and sober staff permitting!
I read how you did your blue lit sign. I saw in your pictures that your sign was an aluminium tray painted (seemed like one) can you tell me how I would go about getting one made? I have been dumped with a sign job, but the customer has requested a similar finish to the signs at Vision express stores. The whole sign looks like one big panel foam coated. Help much appreciated. Thanks. -
all the trays i use are made by me from dibond which is sheet material with 2 skins of aluminium and a core of plastic
these are routed and folded to make in to a tray
hi thanks for the reply. are they then painted? how do you get about folding them? also what do you use to router them? do you do that yourself or do you get it done for you?
quote Emran Shaikh:Hi,
I read how you did your blue lit sign. I saw in your pictures that your sign was an aluminium tray painted (seemed like one) can you tell me how I would go about getting one made? I have been dumped with a sign job, but the customer has requested a similar finish to the signs at Vision express stores. The whole sign looks like one big panel foam coated. Help much appreciated. Thanks.You’ve been dumped with a sign job? What does that mean? Are you a signmaker or not? Just wondered.
haha, yes mate. I generally do a lot with acrylics, vinyl, banners, letters with locaters etc… and some lighting. I just have to do this job but the customer has specifically requested a more shopping centre style upmarket design like the vision express ones.
if i cant get the correct colour for a job i use my mates oven in his car body repair shop and spray them
the router is just a standard hand held jobbie
if you have a look on the boards i have sent in some photos of making a tray
thanks rich
Great job Richard……….
I’m looking forward to someone wanting this type of sign around here, not sure what you lot think but i love it when we get to use stuff that we’ve never used before.
Word of mouth gets round and then you get another and another.Good Stuff.
thanks rich, I will take a look at the posts. Help very much appreciated.
Thanks -
if you need a chat feel free to drop me a line
details on my web site
richgot 3 trays to make tomorrow for another sign company with 55 degree angles will post a few pics
rich -
Hi Richard,
can you give me your web details please.
Also what kind of routing system do you use for cutting out the letters? -
hi mate
the letters are made for me by Vince @ bespoke signs and i make the rest
I’m doing a larger sign this week same letters and blue lighting
customer design !!
will post some pics
richmod-edit please use pm/email buttons
hi mate, i mean how did you get the letters cut out of the dibond?
Emran, not sure if you are asking the right question as Richard says the cut letters are supplied by Bespoke signs, he then fits the LED’s and mounts them onto flat dibond.
Hi Lee,
Im sorry I’m confusing everyone. What I wanted to know was on some of the jobs the letters are cut out on the dibond and then the steel letters are placed on top with an acrylic backing. I was wondering how the lettering was cut in the dibond. Does that make sense?
