Halo Lettering
Hi All,
Just wondered if someone might have some advise on built up Halo lettering.The lettering is approx 1800mm tall spanning 7.5 metres with 50/60mm returns.
I plan to make them out of 3mm front face with 2mm thickness returns aluminium. I presume I then fit a clear acrylic panel which is a snug fit to the inside.obviously this is quite a weight which I plan to fit to Kingspan 50, I do not know what gap should be left between the building and the letter. So to spread the weight instead of using brass locator’s cut a 10mm piece of foamex around 50mm smaller all round the letter screw that to the building, then add the clear panel and then offer the lettering onto this and fix from the sidesof the lettering 😮
I dont know if the gap between the bottom of the lettering and the building is big enough to let the light through to create the halo. Any advise please !!!
Phil
