Home › Forums › Vinyl Cutter Discussions › General Cutter topics › GSP SPRINT PLOTTER DIRECT FROM PC? WILL IT WORK?
Posted by Karl Williams on 30 November 2008 at 21:33I know when i used a Graphix 4b from a pc it had to run from an LMK module. Does anyone know if the plotter from the sprint will run direct from a pc or not?
Cheers,
Karl.Chris Wool replied 15 years, 9 months ago 3 Members · 17 Replies -
Not enough old bugg@rs on here to remember what a sprint is me thinks! 😕
dont know for sure but is that what the omega s/w was for ?
Hello Chris,
Yes, the Advantage and Omega software will run it, But i’m not sure if I need and LMK module (adapter) to make it work. The Sprint was a stand alone unit before pc’s came out. -
do you mean this
http://www.e-engraving.com/machines/ger … int_48.htmor was i think there was a plotter called a sprint
The computer and monitor in the pic are correct Chris but they were connected to a plotter. I’m trying to find a pic now.
now going back a very long time.
i think it was a sprint plotter was sent to me to try against some dos software. because of other software playing up.
end result was memory dodgy here ran DMPL on a serial cable to the old houston plotter pin outs.so summa settings may work think they only had a serial connect.
forget all the above it was not one of these
http://www.tradesignz.com/product_info. … cts_id=256
talking of old plotters there is a houston dmp65 on duffbay looks in really good nick. that was my first roll feed plotter.
That link’s not working mate. Says page cannot be displayed.
after all that i would say no to your question, but then i have to say WHY
quote Chris Wool:after all that i would say no to your question, but then i have to say WHY
Bl00dy Hell Chris! 😕
I’ve got one coming. Would be nice just to plug it in and play. But I don’t think that will happen cos it never does! 😕 😕 🙄
The other thing is I like a bit of nostalgia. These machines are what I trained on years ago. -
quote KW:I know when i used a Graphix 4b from a pc it had to run from an LMK module. Does anyone know if the plotter from the sprint will run direct from a pc or not?
Cheers,
Karl.Hi just seen this on forum, i used sprint with pc for years, i am sure a lmk module was used. do you still have sprint up and running.
jim
