Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Grit Roller Cleaning
  • Grit Roller Cleaning
    Posted by Paul Humble on 14 December 2009 at 11:40
    I think my grit rollers need a good clean as my CE5000-120 has been tracking way off today. Whats the best way to clean them?
    Derek Heron replied 16 years ago 4 Members · 4 Replies
    14 December 2009 at 12:04
    i use a bit of app fluid and an old toothbrush which has had the bristles cut down,
    the they’re gooey at all i use thinners (very small amount) and the brush.
    Hugh
  • Paul Humble
    14 December 2009 at 12:14
    Cheers Hugh I shall confiscate the girlfriends toothbrush tonight!
    14 December 2009 at 13:15
    thick sticky vinyl or application tape pulled through with the machine switched off and the rollers down other way up to clean the rollers.
    or the GF toothbrush only seams fair you don’t want to know what she uses yours for
  • Derek Heron
    14 December 2009 at 15:54
    hi paul
    if your gentle with it a quick rinse will leave the toothbrush good as new
    and save you buying a new one
    derek
