Home Forums Printing Discussions Uniform Printers Grenadier 2 Inspection
  • Grenadier 2 Inspection
    Posted by Jamie Dale on 2 February 2011 at 21:15
    I just inspected my printer I got from B&P last year which I have barely used (I never new the side where the print heads sit in the caps came off also) It looks like ink seems to be leaking from somewhere, or coming back up from somewhere (the dirty brown puddle of ink), I’ve attached a few photos, if anyone has any idea that would be great…. Also would you recommend anything for cleaning wires or anything as they are in a terrible mess.
    Cheers, Jamie 🙂
    Philip Jeneway replied 14 years, 10 months ago 1 Member · 1 Reply
  • 1 Reply
  • Philip Jeneway
    3 February 2011 at 10:47
    Hi you need ‘flush’ to clean the machine which should be done regularly can buy from your ink supplier, I’d leave the wires alone, the flush might eat into them. There should be 2 drain pipes running into the overflow bottle, that’s probably were the inks escaping check their connections & that the small tubes coming from the pumps are push well into drain. If it’s not that you’ve probably got a pump fault you need to have a good search round after cleaning to see where the ink coming from. Hope this helps.
