• Posted by Andrew Boyle on 14 July 2006 at 19:08
    I seem to have a problem with a lot of prints having a green tinge….some materials like digital canvas are especially bad….
    using the JV3, shiraz rip and I’ve tried loads of profiles…any help appreciated….
    Andrew
    eddie meadows replied 19 years, 5 months ago 3 Members · 3 Replies
  • Stuart Whitehouse
    14 July 2006 at 19:17
    I have had this problem a couple of times with my cadet. If its anything like mine it is probably a blockage/contamination on one of the ink tubes.
    basically all i did was clear the blockage and print out about 1500mm of each main colour. i.e. cyan, yellow, black & blue until it eventually clears itself and the colours come back to life.
    hope this helps
    stuart
  • Andrew Boyle
    14 July 2006 at 19:46
    Cheers Stuart will give that a try… [the test prints are perfect!]….
  • eddie meadows
    16 July 2006 at 23:54
    when you say tried loads of profiles. Do you mean you have made these profiles yourself or just used generic pre-made profiles. As you are probably aware each ink/paper/resolution require a new profile for best results.
