Home › Forums › Vinyl Cutter Discussions › Graphtec Vinyl Cutters › Graphtec/ cutting master
Posted by Paul Goddard on 26 September 2009 at 21:09Hi guys design in corelx4 then cut through cutting master but prints backwards and axis are different way round. This is something stupid is there something that needs altering around.
Paul
Paul Goddard replied 16 years, 3 months ago 2 Members · 11 Replies -
at the bottom of the first page press the reset button.
think you have the body (rotate) and F icons checked.
remove the knife to re test with out waisting vinyl. -
Hi Chris tried that but still the same the blue arrow left to right and red arrow bottom to top when i move wording to left of blue arow it goes the red arrow way. (if you understand)
Paul -
is there a mismatch between the page and plotter size and have you tried the poll button.
tried the poll button and still the same its like its all mirrored round?
Paul
i have been trying to duplicate your fault as i understand you.
is the out put mirrored but looks correct in the preview window
Hi mate yes thats it the f is showing the right way and when it prints its mirrored also when i move it on the page the axis seems mirrired.
Paul
this is one of the things (of many) i don’t like about cm2 its trying to be to clever.
i suspect that the mirror function is on on the plotter. also i think rotate as well.
causing confusion with in cm2.cm2 is normally fine for simple stuff only.
chrsi
Hi chris you was right mate they was on, altered them now but it wont print now lol
Paul
typical 😥
switch the plotter off and close corel and cm2.
and start a fresh. -
Hi Chris thanks a lot all seems to be working well now 😀
Paul
