Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters graphtec ce5000 cutting size problem
  • graphtec ce5000 cutting size problem
    Posted by Kevin Parr on 29 June 2014 at 23:09
    Hello all
    i am using cutting master 2 ,1,94 with corel draw x6 and have been for a bit with no problems.But now when i want to cut something out 40mm square the actual size that gets cut is 35mm square.I have checked the step size on my ce5000 and in cutting master 2 which are both 0.1mm so can anyone please help me try anything im going mad ….thanks
    Chris Wool replied 11 years, 6 months ago 2 Members · 3 Replies
    30 June 2014 at 09:17
    can only think a scale is applied
    in cm s properties does the job size show as correct
    or look on the plotter to see if scale has been added
  • Kevin Parr
    30 June 2014 at 10:12
    Hello Chris and many thanks for your reply.Yes the cut size is the same as job size in cm2 but not too sure what you mean about check on the ce5000 if a scale has been added thankyou
    30 June 2014 at 16:03
    in the graphtec plotter menu is a scale
    mine is under function 1 and should say scale 1
