Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec ce5000-60 cutting problem
  • Graphtec ce5000-60 cutting problem
    Posted by Paul Goddard on 11 August 2013 at 19:56
    Hi there i use the graphtec with corel x4 no issues until today. When going to send to the cutter it seems that it cant connect to the cutter and find the poll size. I have tried 3 lots of usb cables and still no joy. Any ideas?
    paul
    Alex Parkin replied 12 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
    11 August 2013 at 22:28
    This probably won’t solve the problem, but sometimes if you tun off your computer then turn it back on, it works.
    You might want to reinstall Cutting Master?
  • Colin Crabb
    12 August 2013 at 08:48
    Just check there is no jobs stuck in the work queue (the separate job box)
    If there an aborted / Part finished job it will prevent the cutter from performing some functions like poll size (had that like gem before, took us an hour to fix that one)
  • Ewan Chrystal
    12 August 2013 at 09:15
    Have you changed your USB port? I had this problem when i moved the office around and it would only work in the specified port
  • Paul Goddard
    12 August 2013 at 13:18
    Hi Jill tried that and no luck
    Hi Colin no jobs in que or aborted jobs
    Hi Ewan no not changed ports.
    Was working ok then nothing just going to uninstall software and try again
  • Alex Parkin
    12 August 2013 at 14:14
    Had the same problem, resolved it by installing Cutmaster 3 the latest vesion is 2.0.73gc.
  • Paul Goddard
    12 August 2013 at 14:42
    Hi Alex have tried that but still no joy anyone know of a graphtec engineer?
  • Alex Parkin
    12 August 2013 at 14:49
    I spoke to an engineer at Graphtec GB and he was very helpful. the phone No is
    +44 (0)1978 666700
    Hope it helps
