Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec ce 5000/60 optical registration marks
  • Graphtec ce 5000/60 optical registration marks
    Posted by Billy Lawton on 20 December 2011 at 22:32
    Hi everyone – I’m wanting to cut inkjet decals (off my vector outline) and wondered if anyone knew where I can download the correct Graphtec registration marks to make it all work when I put the A4 sheet on the cutter.
    I’ve never done this before so any tips would be fab!
    Merry Christmas one and all!
    Billy
    Jason Davies replied 14 years ago 2 Members · 2 Replies
    20 December 2011 at 23:15
    graphtec supply CM2 cutting software for just that use, you will need to do a lot a reading up in the manual and there is a youtube demo.
    a4 is quite difficult to use because of the large margins required,
    call it your xmas break challenge.
  • Jason Davies
    21 December 2011 at 11:08
    If you want to do A4 use pattern 2. You have to create everything inside illustrator first though (or your preferred vector package) and then send to your printer. If you get started and run into problems I can talk you through it. It works but you can lose accuracy on small decals over a couple of metres.
    Good luck.
