Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Graphtec CE 5000-60 going off track – advice please?
  • Graphtec CE 5000-60 going off track – advice please?
    Posted by Martin Gray on 16 February 2015 at 22:13
    Hi Guys and Gals
    I’m Having a major keeping my Graphtec ce5000-60 to stay on track! even with feed! why oh why does these things happen when you’ve got a mountain of work to do!
    I’ve tried cleaning the lower bar checked the rollers are clean and tight. I’ve tried pre feeding 3 metres of vinyl and it goes out fine, and back again. Until the last foot or so. it goes a few mill out but after you start cutting it gets worse and worse. its a brand new roll of vinyl which I normally find better. I think I will phone Graphtec tomorrow to order new rollers but just wondered if there is anything else I could try if that isn’t the problem.
    Martin
    Martin Gray replied 10 years, 10 months ago 4 Members · 5 Replies
  • Kevin Flowers
    16 February 2015 at 22:25
    this can be a backing paper problem, have you tried an older roll of vinyl on the cutter to see if it occurs
  • Martin Gray
    16 February 2015 at 22:37
    Yes I am cutting from a old roll just now and its still all over the place! ive had problems before with this but never this bad. ive seen me feed out vinyl and if it goes off track stop and roll it back on the roll and try again till im happy with it but ive done this so much times tonight its unreal!
    17 February 2015 at 09:01
    are the rollers on the back adjustable? on the rear of the summa I can move the rear-most roller, if it isn’t square it can cause this problem, lots of hea scratching and a very simple cause!
    did one have a roll of LG that somehow appeared to have been cut with a bit of a skew, always ran off so I binned it!
    17 February 2015 at 12:15
    if the rollers have a lever on the rear it is adjustable pressure light or normal should be equal, easy to knock one when loading
  • Martin Gray
    17 February 2015 at 13:04
    I spoke to Graphtec today and he thinks it might be the grip on the lower bar that is worn as it is set up for a full roll all the time! ive tried moving it ever so slightly across abit more but I cant move it much as I still need to cut 580mm. he said to slow the speed down a bit which might help and ive took a blow gun to the rear bar where the bar connects to the rollers as there was abit of fluff between them. that seams to be working better now but think I will maybe still get a new lower roller £180
    Martin
