Graphtec CE 5000-60 24" vinyl cutter
Due to a change in circumstances I am having to sell this.
It is about 10 months old and has had very light use.
Comes complete with stand, power and usb leads, drivers and a spare blade.
It is located nr woodbridge, suffolk and will be collection only.Price: £700 (no vat)
Specs are as follows:
CPU 32-bit CPU
Configuration Grit-rolling friction feed
Drive Digital ServoMaximum cutting area
603 mm x 50 m [23.7" x 164′]
Range of guaranteed precision 584 x 5 m [23" x 16.4′]
Compatible media widths Minimum: 50 mm [2"]
Maximum: 712 mm [28"]
Maximum media thickness 0.25 mm [10 mils]
Maximum cutting speed 60 cm/s [24 ips] in all directions
Maximum acceleration direction 21.2 m/s2 in 45 deg
Programmable cutting force 20 gf to 300 gf in 31 steps
Minimum character matrix Approx 5 mm [0.2"] high
Film types Self-adhesive vinyl film, fluorescent film, reflective film
Interfaces RS-232C serial or USB
Data buffer 2 MB
Command sets GP-GL™ / HP-GL® (control panel selectable)
Number of preset conditions 8 groups, user-specifiable
Power requirements 100 to 120 VAC, 220 to 240 VAC, 50/60 Hz
Operating environment 10 to 35°C [50 to 95°F], 35 to 75% RH (non-condensing)
Dimensions 851x285x223mm [33.5×11.2×8.7"]
Certifications CE Mark; RoSH
