Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters graphtec 3000-60 artcut
  • graphtec 3000-60 artcut
    Posted by Tony Storr on 11 October 2010 at 12:32
    anyone have a graphtec 3000-60 working with artcut . iam needing the settings as just bought a secondhand cutter of which has no info with it .Ive downloaded manual for cutter but wont work with artcut . any help would be appreciated i know artcut isn’t the best software but i use to it thanks
    Tony Storr replied 15 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Alan Wharton
    11 October 2010 at 21:17
    not used artcut myself i use vmp i have same cutter tho, iv just had a quick read of the artcut 2005 manual online and in the initial setup window of artcut how have you got it setup ! have you used the graphtec or hpgl settings? also check the baud rate in the settings. are you using usb or serial. have you installed the drivers for the cutter ! you can d/load them from graphtec site..
  • Tony Storr
    11 October 2010 at 21:33
    cheers mate i ve downloaded drivers and read manual still nothing .
  • Alan Wharton
    11 October 2010 at 21:52
    you installed the ops662 drivers ?
    have you actually got the cutter to cut anything since you bought it!
  • Tony Storr
    11 October 2010 at 22:00
    alan i installed OPS628(v9.00A) driver for xp i dont think its a mark 2 it does test cut
    i did try printing with it and it recognised it as a printer strange but it was cutting vinyl in lines as if it was printing on paper .so its there just the settings which is not configured i guessing
  • Alan Wharton
    12 October 2010 at 01:02
    apart from having the right driver in there im afraid im stuck as i dont know the software, in the setup window of the software you could always try setting it to hpgl instead of the graphtec see if that makes any difference, i would of thought some1 would of come in on this thread who does use artcut there are a few on here.
    1 other thing have you tried cuttting from adobe or any other gfx software you have!
  • Tony Storr
    12 October 2010 at 21:51
    i have tried hpgl still nothing . i have managed to cut using flexi but i like artcut as i know my way round it and most of my stuff i use are in artcut format . iam pretty sure there is some who could help me with these settings just means waiting till the right person comes along . thanks Alan for your help and time
  • Tony Storr
    22 October 2010 at 19:46
    sorted now using printer cable ,usb dont want to work thanks
