Home Forums Sign Making Discussions Vinyl Google fonts and cut vinyl – advice needed, please?
  • Google fonts and cut vinyl – advice needed, please?
    Posted by Phill Fenton on 29 June 2015 at 18:20
    Is it possible to use google fonts to cut vinyl?
    I recall trying to use one of these fonts once before and giving up in despair.
    Any advice?
    Del Blanchard replied 10 years, 2 months ago 3 Members · 3 Replies
  • David Rogers
    29 June 2015 at 20:19
    I don’t think it’s possible to export the fonts out. They are ‘hosted’ by Google for use via CSS code in a web page.
    Saying that…you might be able to make a web page and import it, embedded fonts and all, into Corel or illustrator as an HTML page…then convert to curves and export out…just spit-balling…
  • George Zerbino
    29 June 2015 at 20:28
    You can download all the google fonts here https://github.com/google/fonts/archive/master.zip
  • Del Blanchard
    23 July 2015 at 06:10
    I’m a bit late on my response but yesterday I sent my supplier a file for a quote router cutting and they told me the font was being replaced with an alternative. They told me if I combine the text as a curve (Corel Draw) it would not be an issue. It’s called Unioning in Inkscape, not sure what it’s called in illustrator, but it makes a cut path out of the text, which is then usable.
