Home Forums Sign Making Discussions General Sign Topics Good preparation of plywood
  • Good preparation of plywood
    Posted by Angelique Muller on 24 April 2010 at 19:18
    Hi there,
    Sorry I haven’t posted for a while, but I have been checking regularly on what has been going on here: I am afraid that looking an almost 2 year old is taking up more of my time than making signs.
    Anyway.. I am in my workshop at the moment trying to copy and old pub sign that was falling apart. The owner wants an exact replica. It is made out of plywood. In the past I have had problems with painted ply: paint bubbling etc.
    So I was wondering what the best recommended preparation is?
    I have read that the nature of plywood is to expand/contract a lot, making cracks in the paint that allow moisture in.
    At the moment I have started with a coat of aluminium-primer, and was hoping that 2 coats of undercoat and 2 topcoats, would do the job.
    Would this be any good, or should I be using other materials?
    Any suggestions are welcome..
    Angelique Muller replied 15 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
    24 April 2010 at 19:38
    Hi Angelique, nice to see you around.
    When I do a plywood sign (which used to be all I did at one time) I buy exterior grade plywood from a nearby lumberyard, not a big box store. I hand-pick it to make sure it’s not warped or full of "footballs".
    I cut it to size, sand the edges, blow off the dust with an air gun.
    Then I seal the edges with two coats of Titebond 2 wood glue.
    Then I prime with KILZ brand primer (it’s water based)
    Then sand, blow off, wipe off, then I use 1-Shot or Ronan lettering enamel.
    I dump a puddle of it in the middle of the sign and roll it out with a foam roller.
    The last pass I hold the roller with my other hand and sort of just drag it across the panel, to break any bubbles.
    It rarely needs another coat.
    I use the roller to do the edges of the sign too.
    You can get a glass like finish this way, which when dry is perfect for applying vinyl lettering or hand painting.
  • Angelique Muller
    24 April 2010 at 21:02
    quote Jillbeans:
    When I do a plywood sign (which used to be all I did at one time) I buy exterior grade plywood from a nearby lumberyard, not a big box store. I hand-pick it to make sure it’s not warped or full of “footballs”.
    Hih Jill
    Thanks for your reply.
    I have used high grade WPB and it is a very good surface.
    The product you talk about are brand names that I have not heard of over here, so can you expand on what they are exactly? Is the woodglue a PVA? And the 1-shot paint; is that an enamel paint or just a oil-based gloss?
    Angelique
  • Harry Cleary
    24 April 2010 at 21:16
    Are the edges exposed Angelique? That is the problem area with ply, I would use Marine ply for long term outdoor prestige work and WPB for lesser stuff and I would always try to frame it in some way.
    Make sure to radius all the edges slightly as the paint skin is prone to crack along sharp edges as it expands and contracts.
    You will be fine with Alu primer 2 u/cs and 2 topcoats….make sure to key the surface between the two topcoats.
    And advise the owner to have it varnished at 2/3 year intervals if he wants it to last.
  • Angelique Muller
    25 April 2010 at 10:23
    quote Harry Cleary:
    Thanks Harry,
    It seems really hard to get marine ply: the timber yard here does not stock it and has to order it in especially. They always tell me that unless the ply is submerged in water WPB is fine……
    I will take on board your advice of the radius to the edges and then hope for the best. The ply is going into a metal frame but the edges will be exposed to the elements….
  • Harry Cleary
    25 April 2010 at 10:32
    There should be plenty of boatbuilders down your way Angelique, they might sell you their offcuts.
    WPB is alright but it has to be maintained.
    26 April 2010 at 07:21
    We used to do alot of pub signs at one time and we used ½"Birch faced ply with a frame and rebated capping. This made a good solid sign. The paint regime was 1 primer – 1 undercoat – 1 undercoat/gloss mix – 1 full gloss, rubbing down between coats. The finish was excellent and durability as good as you can expect from plywood.
    Alan D
    26 April 2010 at 11:12
    Titebond2 spex:
    http://www.titebond.com/IntroPageTB.ASP … ?prodcat=1
    KILZ info:
    http://www.masterchem.com/pages/default.aspx?NavID=28
    And Harry is spot-on about knocking over any sharp edges with a sanding block.
    26 April 2010 at 16:18
    We always used WBP, dead right about smoothing the edges.
    Alan D
  • Angelique Muller
    27 April 2010 at 20:46
    Thanks for all the advice!
