Home Forums Sign Making Discussions General Sign Topics Good practice or not necessary
  • Good practice or not necessary
    Posted by Russ on 12 December 2005 at 20:34
    Had to cut some reflective today just a small amount, I might add I don’t often have to use this material. When I cut some for the very first time I thought , that’s my blade gone. To my surprise it carried on cutting vinyl with no obvious effect. After that just to be on the safe side I bought a resharped blade and another holder just for reflective I swop them over as needed is this over the top.
    Regards Russ
    Marcella Ross replied 20 years ago 7 Members · 7 Replies
  • 7 Replies
  • Andy Gorman
    12 December 2005 at 20:41
    If you are cutting reflective all the time it will wear the blade out quicker. It’s a myth that it knackers blades instantly. If set up correctly your blades should last a decent amount of time. I have never found it necessary to buy a different angled blade just for reflective; the standard 45deg works fine for me.
    12 December 2005 at 20:49
    Good practise, always have a spare in stock, and also easier and quicker to change, if its complete with holder.
    Andy is correct, it may not wear out the blade instantly, but reflective does take the edge off it, so if you are doing a lot of small fine stuff, always keep a newish blade for this stuff.
    12 December 2005 at 21:30
    i agree with what has been said so far Russ… good practice to keep one handy but you can get by without.
    reflective is made up of tiny balls of glass sandwiched between the vinyl to create the shimmer when light is bounced off it. its these tiny beads of glass that gradually blunt your blade.
    12 December 2005 at 21:41
    I agree with what has been said here, but I have a blade that is only for reflective.
    No reason other than I started doing it years ago, and never really changed my habit.
    Also, I do a lot of small text in cast material, and the sharper the blade the better. Reflective does take the edge of the blade slowly, and I have been caught a couple of times using my reflective blade on the small cast jobs, and weeding becomes a nightmare.
    12 December 2005 at 21:49
    quote Shane Drew:
    i practice the same and i also felt tip the end of the blade blue so i know its the correct blade im using 😮 blipped a few jobs myself when i left the ref. blade in, vinyl ends up scrunched in the bin 😀
  • Lorraine Clinch
    13 December 2005 at 10:04
    I find that if I use the same blade for vinyl, reflective and garment vinyl the blade goes really quickly. I now keep my last old blade for garment vinyl, and a 60 degree blade for reflective.
    What is the opinion on the cheaper or re-sharpened blades? Do they last as long as the genuine blades (Roland etc), and if not, does the cheaper cost outweigh the replacement time?
    Does anyone understand what I am trying to say, coz I’ve confused myself now! 😳
    13 December 2005 at 10:23
    Lorraine,
    I use resharpened blades and have done so for many years. I have never had any problems with them as they’re as good as new.
    I use the same blade for reflective, although I don’t cut very much of the stuff perhaps that’s why! I just change the settings and it works fine. But as said already, I always have a couple of spares around.
