Home Forums Sign Making Discussions Vinyl Glue Remover Chemical
  • Glue Remover Chemical
    Posted by DaneRead on 20 October 2008 at 14:51
    Got both sides of a 15mt x 2.5mt trailer full of old glue.
    Has anyone got a better idea then the follwoing:
    Auto Glym Tar and adhesive remover not strong enough.
    3M Adhesive Remover not available not stock will take 3 months.
    Rub it vinyl glue remover too expensive and not that effective
    Petrol not bad but its makes the glue all guey and you end up getting a spreading the glue mess from one side to the other.
    Thinners does the same thing
    Im racking my brain. but i cant think of normal type of chemical that can do . We can also mix thechemicall up ourselves form a chemical manufacturer if necessary.
    Has anyone got a better way of doing this.
    Thinking about MEK has anyone tried this.
    Ade Brown replied 17 years ago 13 Members · 18 Replies
  • 18 Replies
    20 October 2008 at 15:06
    Rapid Remover by the folks who make Rapid Tac.
    It’s not cheap but it works and saves a ton of labor.
    Love…..Jill
  • DaneRead
    21 October 2008 at 13:07
    thanks for that.
    rapid tac does not have an African distributor so i cant get it in time.
    bit of a mess.
    i was really looking for a standard type of chemical.
  • Gavin MacMillan
    21 October 2008 at 13:41
    Not first options but:
    a pressure washer/steamer thing… you know what I mean? I’ve used these to remove vinyl before and they take the glue as well.
    Wall paper steamer – normally use for removing vinyl but it will soften glue enough to use a squeegee to get it of
    21 October 2008 at 13:50
  • DaneRead
    21 October 2008 at 14:34
    hi jill have you tried this stuff before.
    What is the common use for orange terpene
    21 October 2008 at 14:39
    No, I haven’t.
    But I have heard that it is the main ingredient in Rapid Remover.
    And also that it is water soluble.
    You can dilute it with water as needed.
    Here is a direct quote from another sign forum:
    quote :
    You can go to or order from
    any janitorial supply co; some (orange terpene)
    or some (d-limonene), both products are made from
    orange peels and can be watered down some (to your
    own specs) and also cleaned off with soap and
    water.
  • Ian Muir
    21 October 2008 at 16:04
    I always use simply white spirit, works if you time it right and are logical in approach.
    Wipe it on lavishly with a cloth, wait a minute or so and agitate it into the glue with a cloth, a foam sponge or a scotchbrite pad (depending upon the substate i.e. whether it is harmed from scratching excessively).
    For your size of work I’d make a couple of long scrapers from foam pvc and after waiting another couple of minutes start wiping down from top to bottom,should get 3/4 off in big sticky balls.
    Repeat, should get another 3/4 off of the 1/4 that’s left.
    The remaining should wipe down with a cloth after another soaking in white spirit.
    Ian :lol1:
  • DaneRead
    22 October 2008 at 10:57
    thanks for the advise i will try and locate the chemicals and get back to you.
    We did have good results yesterday with petrol and thinners mix. Paint it on with a paint brush then scrape it off with wide window blade scrapers. Seems to do the job pretty well.
    22 October 2008 at 11:26
    quote DaneRead:
    This is all I use.
    Called many names, but Orange Solv is the most common, or a derivative of that.
    Brilliant glue remover, and makes your hands smell lovely too
    Removes ink, grease, tar, oil and glue. Good all purpose eco friendly chemical
    22 October 2008 at 11:33
    quote DaneRead:
    petrol and thinners mix. .
    hope nobody smokes at your place. Dangerous mix mate. Its illegal to use that here actually. WPH&S would have a fit, and big fines too…… 😮
  • Robert_James
    24 November 2008 at 18:13
    WD40 might do the trick
    Not sure though
  • Jason Xuereb
    24 November 2008 at 23:56
    We use citrus solvent. Leave it in the sun, wash it down, spray the citrus on, leave it for 5 minutes, pressure hose it off and repeat. You can use a plastic squeegee as well to scrap the goop off.
  • Paul Humble
    25 November 2008 at 00:04
    Its a pity you cant get Rapid Remover because its unreal how well it works!
  • Michael Potter
    25 November 2008 at 01:03
    yep orange solv works really well. Methylated spirits works well as well depends on substrate i guess.
    cheers Mike
  • Jason Adams
    25 November 2008 at 13:11
    "Jelsol" or "GELSOLV"
    Aerosol – Chewing Gum, Label & Graffiti Remover.
    Quickly removes chewing gum, labels and graffiti from fabric and vinyl upholstery, floors and walls.
    THIS STUFF WORKS BETTER THAN ANYTHING ELSE I HAVE SO FAR DISCOVERED INCLUDING GRAFITYP’s EXPENSIVE GLUE REMOVER!
    I get it from Autosmart (www.autosmart.co.uk) who deliver it to my door via their rep for the area, It costs me about £3 a can normally.
    Trust me, this stuff is the feshnizzle for removing glue on vehicles, boards etc, Spray on and wipe off with the utmost of ease…honestly.
    One Can lasts me ages.
    Jay.
  • Steve Underhill
    25 November 2008 at 14:07
    Concept tar and glue remover,
    works better than Right off, avery, all the expensive ones, Car valeters use it and I have a 5l can here just used it to get some welded on masking tape off a window one spray, no waiting and its off works extremely well with very old adhesive too
    and its 12 quid for 5 litres!
    heres a link
    http://www.autojoy.co.uk/concept-tar-gl … p-241.html
  • John Harding
    25 November 2008 at 17:44
    is this it shane?
    http://www.cleanerswarehouse.co.uk/shop … c3ffe7f15f
  • Ade Brown
    25 November 2008 at 18:19
    I use Autosmart tar & glue remover and Wurth’s Decal remover,
    both of them spray on leave a minute or two and use gold squeegee to remove and then just wipe!!
    John the clears warehouse is just down road from me, might do some testing with that product!!
    Ade
