• Stephen Morriss
    3 February 2012 at 09:13
    Special Glue George :lol1:
    I use VHB tape and a corner bracket, you have to make sure you have the corner sitting nicely though as it tries to pull off if there’s to much strain
    I once saw a way to make nice corners in trays but now I can’t find it so I’ll be keeping an eye on this thread.
  • George Elsmore
    3 February 2012 at 09:18
    tried a hot glue gun but corners popped glad the tray is not up and still in the unit …need an answer 😕
  • Stephen Morriss
    3 February 2012 at 09:25
    You could try countersunk pop rivets and glue.
    I think if your tray sides are pulling hard on the corner brace then your better off with a mechanical fixing like a rivet or screw, a hot glue gun isn’t the right sort of glue anyway, try Araldite or similar.
  • George Elsmore
    3 February 2012 at 09:27
    didnt wanna go down the rivet road as i have bought trays that have been glued 😕
  • Ian Johnston
    3 February 2012 at 09:42
    Polyeurthane adhesive Sealant like, Tiger Seal, etc.
    you’ll get it at a car parts shop or the likes.
    Sand the panel with a coarse paper and use a small piece of ally angle to give a brace, glue it , then using a bit of tape to hold it in place till it cures, approx 3hrs to set, 48 to fully cure
  • Stephen Morriss
    3 February 2012 at 09:43
    Hi George
    I just did a search on ‘glue alubond’ in google, 6th one down is a pdf guide to fabrication with Alubond, it may give some pointers, page 10 shows 2 corner options and page 20 shows gluing.
  • Dave Rich
    3 February 2012 at 10:45
    We use an acrylic 2 part resin, around £7-00 a tube and it takes a hammer to break apart….very strong stuff. Try Innova Solutions.
  • David Rogers
    3 February 2012 at 19:01
    I’ve always used evo-stik ‘serious stuff’
    works very well once it goes off (rubbery).
  • Richard Urquhart
    3 February 2012 at 20:59
    This is the best stuff
    HS300
    AUTO/MARINE STRUCTURAL
    from huttonsupplies.co.uk
