Home Forums Sign Making Discussions General Sign Topics Glue for digital vinyl
  • Glue for digital vinyl
    Posted by Jonathan Wallace on 17 January 2011 at 09:32
    I have been asked by a client to apply a large vinyl image of a pie to his flour sylo at his bakery. However after inspection of the surface it would appear that it is less than a smooth one. Does anyone have any advice on a glue that will help to bolster it’s adhesion.
    Shane Drew replied 14 years, 11 months ago 3 Members · 5 Replies
  • Ian Johnston
    17 January 2011 at 09:45
    is it on a flat plane, or curved, Mount onto 1mm foamex then glue to silo,
  • Jonathan Wallace
    17 January 2011 at 11:08
    It is on a curve and it’s size is 4510mm x 2270. We print it in 8 sections with overlaps similar to a billboard
  • Ian Johnston
    17 January 2011 at 11:23
    i’d still go the Foamex route. Easy install, and if the surface is bad before, by the time you’ve the print on it’ll look even worse.
  • Jonathan Wallace
    17 January 2011 at 11:43
    What adhesive would you recommend?
    17 January 2011 at 11:53
    3M do a film especially for rough walls.
    http://solutions.3m.com/wps/portal/3M/e … RoughWall/
    you can do everything from concrete to brick. Thick adhesive, applied with heat.
