Home Forums Sign Making Discussions Off Topic Chat Gloss Black 5mm Foam
  • Gloss Black 5mm Foam
    Posted by signworkshop on 24 October 2004 at 22:03
    Hi all,
    Can anyone tell me where I cna get some gloss black 5mm foam, is it called Foamulux, plus how much would a sheet of it cost?
    Kind Regards
    From
    Mark A Brown
    Phil Davies replied 21 years ago 9 Members · 10 Replies
  • 10 Replies
  • J. Hulme
    24 October 2004 at 22:08
    We just flood it with whatever colour vinyl we need 😕
  • MikeO
    24 October 2004 at 22:29
    We get ours from Paragon Imaging Materials (part of Robert Horne Group), haven’t bought the gloss though, only matt. I think an 8x4ft sheet is about £20 (ish) but can’t be certain – failing memory I’m afraid!
    Mike
  • John & Dawn Roddick
    24 October 2004 at 22:47
    Europoint sell it too. Not sure how much they charge.
  • Carrie Brown
    24 October 2004 at 23:18
    Amari to it aswell 😀
  • Phil Davies
    25 October 2004 at 05:34
    cox plastics
    priced last week for a job £47 a sheet in gloss 🙄
    too expensive for us
    we flood coated white 5mm matt with black gloss
    £17 +vat for board + vinyl + my time
    alot cheaper same result :lol1:
    regards
    phil
  • signdevil
    25 October 2004 at 08:13
    Paper Co (Europoint). They call it ‘Forrex Tops’ and you should not pay more than £30 for a sheet of 5mm. I would not advise covering std foam with gloss vinyl because vinyl scratches show very easily, especially on black !
  • signworkshop
    25 October 2004 at 08:51
    Phil, when you flood the foamex, do you fold the vinyl around the edges and around to the back, otherwise you get horrible white lines showing when you have a join in the panel.
  • evox
    25 October 2004 at 16:04
    Amari in Cardiff charge about £30.00 for an 8×4 (from memory!!).
  • John Singh
    25 October 2004 at 16:21
    One trick when flooding is to paint the edge of the board before applying the vinyl
  • Phil Davies
    25 October 2004 at 19:34
    yes mate always return vinyl around edges where 2 boards joins but my job was going in euro trim so didnt see outer edges so just trimmed flush
    but signdevil is right must have good good boards
    cause black gloss shows every scratch
    if i could get black 5mm gloss for £30 i wouldnt of
    bothered to flood them not worth the hassle
