Home Forums Printing Discussions Sublimation Printing getting right colour
  • getting right colour
    Posted by Adele Brennan on 15 January 2009 at 23:46
    Using corel x3 and trying to get a red like pillar box red without success.
    Colour is coming out like a salmon pink. Looks dark on paper but once its on mug it is very light.
    Any help appreciated.
    Peter Mindham replied 16 years, 11 months ago 3 Members · 3 Replies
  • Chris Lambe
    16 January 2009 at 10:31
    Adele to get a pillar box red your cmyk values should be 100% magenta & 100% yellow should be spot on then
  • mbroad
    17 January 2009 at 09:56
    Have you checked to make sure the colour correction profile is correctly installed in Corel and also double check your settings in the Epson driver. Assuming this are fine try pressing your mugs for an extra 20-30 seconds as the length of time you press for (and the higher the temperature in your mug press) will darken the image reproduction on to your substrate (mugs, ceramics, textiles etc).
  • Peter Mindham
    18 January 2009 at 08:10
    Red is a hard colour to produce on dye sub migs in my experience. It is a bit trial and error but do as mbroad suggested. Remember though, that you will reach a limit where the colour will start to bleed so keep a look out for that.
