Home Forums Sign Making Discussions Vinyl Getting a good red with CMYK
  • Getting a good red with CMYK
    Posted by Paul Richards on 25 February 2013 at 20:40
    Ive been trying to get a good red with my inkjet epson printer
    Obviously I used C=0 M=100 Y=100 K=0(and variances up tp 20)
    But the color still has a heavy magenta tint to it
    Is there anyway to get a true red with CMYK or will I just be limited
    Thanks in advance
    Paul Richards replied 12 years, 7 months ago 6 Members · 16 Replies
  • 16 Replies
  • David Rogers
    25 February 2013 at 22:11
    it will basically vary by printer / ink & rip set to an extent.
    I suggest you pick an image that you KNOW has a good red and prints well (eg, print a coke can) and sample that CMYK value with a graphics program to get that value.
  • Lee Attewell
    26 February 2013 at 05:10
    Why not print yourself a CMYK colour sample grid with breakdowns of colour? That way you can have samples of the red you want for with different media.
  • Glenn Sharp
    26 February 2013 at 07:28
    I’ve found that the way you send the job through to the rip can give you variations of colour aswell
    publishing as PDF for Document Distribution and publishing as PDF for Editing should give the same colour chart a very different look
  • Paul Richards
    26 February 2013 at 23:19
    Thanks for that guys
    I have the red colors I like on screen, but when i print them onto my media, they are not red, but seem to be magenta trying to be red
    If that makes any sense
    Right now I am printing straight from Illustrator CS4, but maybe I will have a go at printing from a pdf of file, see how that turns out
    27 February 2013 at 00:01
    What sort of paper or media are you printing on really needs to be a photo quality to get good reds etc.
    Presumably the yellow is printing correctly
  • Paul Richards
    27 February 2013 at 11:37
    Hi Chris, the output has been on gloss printable vinyl and Ive done some tests on high quality photo paper, but still the same result
    NOt red, but magenta pretending to be red…..lol
    27 February 2013 at 11:46
    are you using cheap inks as the yellow in normally poor??
    i would print a row of 20mm sq boxes with 100% colours
    black yellow magenta cyan they should print solid colours no speckeles of any outher colour in them if there is then you have a profile problem
  • Paul Richards
    27 February 2013 at 12:34
    Hi Chris, thanks for that
    I would nt say that they are expensive inks…..lol
    Did what you said and there are dirty color speckles in all of them
    The black doesnt seem jet black either
    So what do I need to do to change profile?
    Many thanks
    Paul
    27 February 2013 at 12:44
    try
    under print comand
    in misc
    untick apply icc profile which is the one i think is giving you trouble.
    try a test print as before
  • Paul Richards
    27 February 2013 at 13:49
    Hi Chris, im currently trying what you advised
    But there are profiles for illustrator and printer software?
  • Paul Richards
    27 February 2013 at 14:14
    Hi Chris, think Ive found the issue
    On my printer management, it was set to Vivid
    Ive changed this to RGB 2.2 Gamma
    This seems to be a lot better on the CMYK strip, but will know more on design investigation
    Thanks for pointing me in the right direction
    Paul 😀
    have not a clue with illyfustrator
    you need to send the file to the printer driver unmolested the printer profile adjusts ink levels and resolution for different types of media.
  • Paul Richards
    27 February 2013 at 14:16
    Ok, great
    Paul
  • Paul Richards
    27 February 2013 at 21:18
    Hi Chris, Im kind of getting close
    So thought I’d post my settings to see if any feedback
    Color set : Euro coated v2
    Assign profile : Euro coated v2
    Printer management(Epson) : RGB 2.2 or for a tad lighter 1.8
    Printer profile : RGB
    Still not 100% happy, but like you said, could be the quality of the inks
  • Jamie Dale
    28 February 2013 at 23:40
    quote Paul Richards:
    Just get your printer profiled correctly. A few years ago I used http://www.pureprofiles.com before I got my own spectrophotometer. The outputs were far better with using the correct profile for the ink. If you are using cheap third party inks most likely there won’t be any profile for them so you will have to get it custom made. 🙂
  • Paul Richards
    3 March 2013 at 11:21
    Hey Jamie, thanks for that
    Looks really good
    Probably give it a go when I get a CISS system for my printer
    Many thanks
    Paul
