Gerber P2C1600S Calibration
Morning all,
I have a Gerber P2C1600S and have been having problems with it being off by quite a bit when cutting lengths
I am using composer to send data to the cutter.
For example if I set up a panel in illustrator 1160 x 295mm, output to a version 3 EPS and then import into composer, composer will show the size correctly until I output the selected data, then it will show a material usage of 1163 x 295mm, and then cut a panel that is 1151 x 294mm.
I have tried calibrating the unit through the calibration menu, the machine will only let me calibrate X and even then the settings do not seem to stick as it will be slightly off again if I re-test it.
I have a job coming up shortly that will need to cut panels to exact sizes so this is no good at all! One of the panels will be over 2.3 metres long and it is on frosted vinyl which is not cheap if it cuts too short!
Any help or ideas appreciated.
Graham
