Home Forums Vinyl Cutter Discussions General Cutter topics Gerber Fastrack 1300 help
  • Gerber Fastrack 1300 help
    Posted by Robert Rowlandson on 24 October 2013 at 12:49
    I’m new to the sign trade and I’ve just got a Gerber Fastrack 1300. We have just performed a test cut using the machines built in test cut feature and while the quality of the straight lines are excellent if you look closer the round edges of the numbers 0 and 8 seem bumby and not crisp and round.
    Any ideas what this could be?
    Cheers guys
    Rob
    David Matthewman replied 12 years ago 2 Members · 3 Replies
  • David Matthewman
    22 November 2013 at 09:34
    hi i’m new on here ,but used the fastrak for years , you will get that wavy edge
    around curved parts , if the letters or numbers are small and speed is to high ,
    we ran ours on min , check the blade is clean sharp and able to rotate ,
    the grip wheels need to be clean and vinyl straight and flat on the bed ,
    use a smart blade
    if your not sure how to remove and insert the original ,
    depending on your software
    you can adjust sharpness and corners as well , hope this helps
  • Robert Rowlandson
    22 November 2013 at 09:49
    Cheers Dave, I found that it would cut wavy lines when using the built in test cut but when I cut from a signlab demo it seems to have stopped!
  • David Matthewman
    22 November 2013 at 09:51
    plus we used to get wrinkles at the beginning on the roll so pull the vinyl through
    200 mm before gripping it , on the artwork we would put a full stop about 2 inches
    in front so it wouldn’t start cutting right on the edge of the vinyl ,
