Home Forums Printing Discussions General Printing Topics gerber edge not working
  • gerber edge not working
    Posted by JIM WATTS on 1 March 2005 at 14:57
    😥 Turned my edge on and nothings happened checked fuses and switch all ok as it is no longer under warranty does anyone know who could mend it without having to pay spandex prices
    payads replied 20 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Marekdlux
    1 March 2005 at 15:06
    Hi Jim,
    I know in the states some of the outlets have their own mini-circuit breakers built into them. Is it possible to plug it into a different power source? I’m probably no help at all, but what the heck?
    -Marek
  • JIM WATTS
    1 March 2005 at 15:15
    Thanks Marek Gave it a go but still dead as a dodo Power is going into the power block but not coming out
  • Marekdlux
    4 March 2005 at 03:32
    CAn you give us an update when you find out what the problem was? Thanks.
    -Marek
  • JIM WATTS
    4 March 2005 at 13:38
    Sure will do.
    19 April 2005 at 11:18
    We are using Edge 1
    We just had the same problem, ended up replacing lots of capacitors/things on the board by paying an expert.
    Power supply boards apparenty was redesigned many years back and so forth and exchange boards are a bit costly. Seek engineer help that’s if you haven’t already.
  • JIM WATTS
    19 April 2005 at 13:03
    Thanks for your message. There is an update to our edge as there was power going into the power block and not coming out we decided to put a new one in and now its working again.
  • Henry Barker
    19 April 2005 at 15:44
    Could it be a faulty power supply in the Edge and not anything more than that?
    I have an Edge, sorry, can’t help you more!
  • payads
    21 April 2005 at 20:45
    If its an edge two, there is a small recess beside the power cable, this holds two extra fuses, one is a spare, check them out, not just the fuses in the plug, the fuses will cost 50pence.
    Frank
