Home Forums Printing Discussions General Printing Topics Gerber Edge Help ! !
  • Gerber Edge Help ! !
    Posted by dicko on 11 March 2003 at 19:44
    HELLLLP (hot)
    Anyone know the answer to this one? I’ve got Edge Mk. 1 and want to print a picture of sky with clouds (bitmap). The picture only needs shades of blue & black, but I can’t find a way to tell the printer to use only those colours – it wants to print process & waste loads of yellow & magenta.
    Can I somehow make it use only those 2 colours?
    Tips much appreciated, I can tell you! 😛
    Bob Gilliland replied 22 years, 10 months ago 3 Members · 3 Replies
    11 March 2003 at 20:24
    I’m not sure if the edge is the same, but I know that when printing with a colorcamm the image need to be vector drawn artwork with spot colours in order to print spot colours. Any rendered images (e.g. bmp, jpg) which consist of individual pixels of colour can only be printed as process colour. The answer is to convert your artwork to a vector drawn graphic, introduce spot colours and then print, however certain types of image do not convert to vector drawn satisfactorily. I suspect the Gerber edge will be subject to the same restrictions.
    You could also try “posterising” the image which will convert the individual pixels to a limited range of colours (i.e. in this case 2) then print as spot colours (However, I’ve never tried this myself – so I’m not sure if it would work).
  • Jon Aston
    11 March 2003 at 21:14
    Dicko (and any other EDGE users reading).
    Try posting this question in 4EDGEtalk.com…plenty of your peers to ask!
  • Bob Gilliland
    11 March 2003 at 21:44
    If you are using Graphix Advantage or Omega, you currently have two options available if you are wanting to remain within the Gerber software; output as a single color gradient or a process job. If going process, you can elect to output using only CMY forgoing the B, or use the traditional CMYK structure. If electing CMY output only, be sure to change your color correction so that the use of CMY will represent Black more appropriately.
    If you are using SignLab e6.1 with the thermal module, you have the ability to output using one, two, three, or four colors of your choosing (along with other options in the design or output areas) by taking advantage of the “Multitone Bitmap” feature. (Actually, it could up to eight spot colors if using Dutones as your selected colors, but that can be addressed later.) This is one of the reasons this feature is included and intended for. I’ve been experimenting with this feature again recently and have produced some neat prints that aren’t easily achievable within Gerber’s software.
    Your other option would be to use a “painting” program like Photoshop or PhotoPaint to separate your image into “two” images. There are multiple ways of doing this with some more appropriate then others depending on the image. In the big picture, you want to create a “Black” image and a “Blue” image file. Within Gerber’s software, you can then assign each image to be rendered with a single color and elect to Overprint one of the images for your desired result.
    Rushing through this, so please ask for clarification if needed.
    Phill,
    Get a hold of a SignLab e6.1 demo. You can make the ole ColorCAMM sing a completely different tune then what it can currently do. The Multitone Bitmap feature mentioned above is just one of a plethora of offerings. 🙂
