Home Forums Sign Making Discussions General Sign Topics georgian windows..
  • georgian windows..
    Posted by Hugh Potter on 14 October 2007 at 16:47
    hi all,
    i have a 2410 x 400 landscape sign to fit, but it’s o a curved facia above a georgian window, i guess the curve protrudes around 2ft. i have quoted dibond for this job, but just thought that i should double check on it’s suitability,
    i was gonna apply the vinyl and then fit around the curve, fixing at one end first, and then every two feet top and bottom, as i pull it around the curve.
    is that gonna work fine ?
    thanks in advance.
    Hugh
    Glenn Sharp replied 18 years, 2 months ago 3 Members · 4 Replies
  • Glenn Sharp
    14 October 2007 at 17:22
    I can’t see why not Hugh….go for the 2mm just to make sure
  • Kevin Flowers
    14 October 2007 at 19:13
    Hugh
    start fixing from the center out each way
    15 October 2007 at 13:10
    cheers guys, i was gonna use some 3mm i had in stock, would this not be suitable ?
  • Glenn Sharp
    15 October 2007 at 13:22
    yeah….just if you were buying it in 2mm would have been easier 😀
